X-brace creaking....
Old May 6, 2003
opto_isolator's Avatar
I just finished off stiffening my chassis by installing the spoon sports rear upper strut bar. I have noticed (before installing the bar, just recently) that I am starting to hear a lot of creaking coming from the front end of the car (probably where the x-brace is installed). This happens on braking or cornering......
I have checked the torque of the bolts, and they look good. The only thing I've noticed is that when I had the car up on jackstands with the wheels off of the ground that the x-brace had a slight upwards bow to it - Don't think its supposed to look like that....
Anyone have any ideas?
Old May 7, 2003
RoadRunner's Avatar
maybe, put some lubricant or WD-40 on the areas where the bolts are connected, just my advice. i'm not sure if that will help anythin
Old May 7, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Would it be better if the final torquing down of the mounting bolts occoured after the car was lowered back to the ground? Opinions anybody?
Old May 7, 2003
I'm going to try and take the brace out and see if it is warped. If it is I'm going to try and get in touch with neuspeed and see what the deal is. The subframe should not be flexing THAT much where it would cause the bar to warp! At this point I'm not too sure what is causing the creaking, it could be the damn control arm since I had the bushing changed out from Honda. If anyone else has any ideas, please let me know - otherwise I'll place my findings here.
Nacho4750
Mar 29, 2007 11:28 AM
tamazoid
41
Oct 11, 2005 02:06 PM
Blahman2
Apr 28, 2005 02:45 PM
AntDeezy
North Cali
19
Feb 4, 2004 12:32 PM
opto_isolator
Jul 7, 2003 02:59 AM
