Tein Owners - Please read
Old Apr 23, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Has anyone else run into alignment problems when their car is lowered to the max on Teins....I probably have a 1 finger gap on my car with the current settings (on 17" rim with 205/40/17 rubbers). The shop is telling me I need to raise it up some or it might rub on the fender...anyone else run into this?
I was suprised to hear this since I have 17s...
Old Apr 23, 2003
DizWikedCivic's Avatar
how low is it lower, i have 205/40/17 w/ 2.75" drop w/ no finger gap and i dont rub
Old Apr 23, 2003
aw low as Tein's will go pretty much...mebe 1/4" from the bottom
Old Apr 23, 2003
if you have 1 finger gap then you shouldnt rub, but in the rear you might rubbed pendin on the camber
Old Apr 23, 2003
thats the concern...the rear...if the camber is properly adjusted, he's afraid ill rub going over a bump or what not
Old Apr 23, 2003
robbclark1's Avatar
Retired suspension supermod.
yes, that is a concern. If you camber is adjusted to -.1 or -.2 (which is should be, then you might rub over bumps. There is a chance and think that is what he is warning you about. If you keep the camber more negative then you should have no problem with it rubbing your fenderwall, but your tires will wear unevenly.
Old Apr 23, 2003
civicvtec1ps's Avatar
Search and Learn
mines doesnt rub on rear. i have tein ss with stock tires 185/65/15. about 1 finger gap. i think you will be fine with that drop. putting my rims tommrrow or friday. 215/45/17 i might have to raise up rear little bit
Old Apr 23, 2003
RedDragon333's Avatar
i never had the rubbing problem but i did anticipate this so i didnt lower it the all the way.
beeemerdude
Jul 10, 2015 09:22 PM
ZILLA
Jul 10, 2015 06:05 AM
Hqly2001
General
Jul 8, 2015 04:07 PM
robbie374
Jul 7, 2015 02:56 AM
