Striped Screw Removal?
Old Apr 17, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, I have been wanting to put on my rear OBX strut bar for the longest time now. About a year ago when I attempted to put it on, I striped one of the bolts on the drivers side where the strut bar goes under. I was an idiot, and not thinking, I kept trying to unscrew it the wrong way with a bit with teeth. I tried to get it off today the right way, put WD-40 on it, and kept trying to remove it, but it is almost rounded. Is there anyway to remove this striped bolt?
Old Apr 18, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
Hmmm not sure on anyways to take it off unless you had a air ratchet to take that right off
Old Apr 18, 2003
flotsamm's Avatar
Bolt or nut? The bolt is actually part of the strut mount. If its the nut, you might be able to get some vise-grips on it if your lucky. Or if you have a dremel or air-chisel, those will cut it off. Just be careful..
Old Apr 18, 2003
VNlilMAN's Avatar
The Standard One
yup, vise grips always work
Old Apr 18, 2003
djmota's Avatar
use a nut cracker to cut the nut or buy one of those gimicky stripped nut removal tools.
Hope you learned to use the right tool next time..
breanna_17
Jul 21, 2015 04:01 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
ballmich
Jul 9, 2015 11:59 AM
CivicsClass101
Jul 9, 2015 11:14 AM
