Koni Schocks
Old Mar 22, 2003
ExcellCivic's Avatar
ExcellCivic is an unknown quantity at this point
Koni Schocks
I am getting ready to install Eibach Pro kit lowering springs.
Is it a good idea to also purchase/install Koni shocks with these springs.
Do these Koni shocks install within the factory housings ok and without
problems?
Old Mar 22, 2003
SDE's Avatar
SDE
SDE is an unknown quantity at this point
It's a good idea if you have the money now. Eventually you are going to need to replace the shocks because they will blow out. There is no time-line for when they will blow out but expect sooner then stock. Could be anywhere from a day to 10 years after you install the springs. The rear Koni shocks install exactly the same as the rear OEM shocks. The front Koni strut is an insert so you will need to use the factory oem strut. There are DIY's on this you just need to search for them. I good search would be accomplished by going to the suspension section of the forum & by typing in KONI.
Old Mar 22, 2003
Thanks for the information
Old Mar 22, 2003
Elite's Avatar
Elite is an unknown quantity at this point
can you have koni front shocks with stock rear shocks cuz my front right shock blew out the other day and I need to replace my stock shocks thanks. Is there gonna be a difference in how it rides and stuff like that? or what? thanks again!
Old Mar 22, 2003
SDE's Avatar
SDE
Yes you can replace both front shocks with Koni's & leave the rear shocks as oem. It would also work the other way around. The only thing you cannot do is have one front shock being Koni and one front shock being OEM & Vice Versa.
Old Mar 22, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
wouldnt ur shocks last pretty long since its a prokit and only bout a 1 inch drop. I want to lower my car with the prokit but i dont have money for shocks and personally dont want to spend the money on them so i am hesitant, i dont know if its a good idea... how much r these konis and how much for the install, thanks
Old Mar 22, 2003
rac53041's Avatar
rac53041 is an unknown quantity at this point
typically they would last but the front struts on our car tend to leak
I have seen many come in the shop with struts leaking with stock springs mine are leaking after a year and a half after installing the prokit so I'm looking to get struts too
does any one know if there is any other brand of struts out yet
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
cukaracha
Aug 29, 2015 05:27 PM
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
