koni shockss
Old Mar 22, 2003
VRoomPSHeRt's Avatar
VRoomPSHeRt is an unknown quantity at this point
Question koni shockss
i was wondering how hard it is to adjust the konis'. my friend with the KYB's were really easy to adjust; juss like a little clip the turns on top of the strut..was wondering if konis are as easy.. thanksss i was searhing, but couldnt find much info on the adjusments n stuff..any info would help thanks guyS!
Old Mar 22, 2003
Roy's Avatar
Roy
Roy is an unknown quantity at this point
very easy, just turn a ****. At the top of the rod.
Old Mar 28, 2003
Vegeta's Avatar
Vegeta is an unknown quantity at this point
the front are easy, but that rear are very hard to adjust. On mind, you can even use the **** cuz there is no room to put it on.
Old Mar 28, 2003
thanks! know somewhere i could get it cheaper that tornactive??
Old Mar 28, 2003
Maverick's Avatar
Maverick is an unknown quantity at this point
yeah, just a tip...if you get konis, adjust the rear before you put them in.after they're in you'll have to use needle nose pliers due to lack of clearance for the ****
Old Mar 28, 2003
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
for the rear, i had to bent the body panel in order to adjust easily
Old Mar 29, 2003
JCap's Avatar
JCap is an unknown quantity at this point
Re: koni shockss
KYB are out for our car?
Old Mar 29, 2003
flotsamm's Avatar
Nah.. not yet. He must be referring to a different generation or car.
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
cukaracha
Aug 29, 2015 05:27 PM
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
