bump guards
Old Mar 16, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
bump guards
i have neuspeed sport springs and i wanted to know if i had to modify the bump guards
its less than a 2" drop so i dunno
Old Mar 16, 2003
flotsamm's Avatar
For a smooth ride I would cut them about an 1" all around. The tricky part with the fronts is getting them to stay up on the strut. I took some rubber hose and wedged it in between the strut and dust cover then zip tied them around.
Old Mar 16, 2003
Elite's Avatar
Elite is an unknown quantity at this point
It really doesnt matter if they are up or not just as long as they are there to protect the strut
Old Mar 17, 2003
andyman97's Avatar
Turbo Guru
The answer to your question will be found with whatever type of springs you have. Some recommend it, some don't. I know people who have 18's with a 2.25 inch drop that haven't cut there's and have no problems. I lowered mine 1.75 and I did trim them. I would do whatever the spring calls for though.
Old Mar 17, 2003
Bartkat's Avatar
I trimmed my bump stops per instructions when installing ProKit and Koni's. Otherwise the car might be hitting the stops too much and not allow full spring and shock travel. I agree though, you should go with the spring company's reccomendations.
Old Mar 17, 2003
flotsamm's Avatar
Only problem I had with mine is when I cut my front dust covers they didnt protect the strut piston since there was nothing to hold them up.
Old Mar 17, 2003
VNlilMAN's Avatar
The Standard One
"For a smooth ride I would cut them about an 1" all around"
cutting bumpstops doesnt really effect ride quality...
ya just cut it to whatever they recommend i think it was like 1" in the rear none in the front...
Dawit Melese
Oct 4, 2015 08:02 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
TheRiddicles
Sep 21, 2015 01:28 AM
