Do I need to get alignment?
Old Mar 16, 2003
Smartidiot's Avatar
Smartidiot is an unknown quantity at this point
I jsut installed H&R sport springs on my 2002 LX coupe stock rims. And now, my rear tires look a little negative toward the centre of my car. Since I am not going to get a camber kit, can anyone tell me if I need to get my car aligned or its okay this way?!?!?!..... and plus, if i do need to get it aligned, where can I get a good job and how much does it cost??? ..
ps: I live in Toronto Canada.
Thanks for the advices.....
Old Mar 16, 2003
Gizmo's Avatar
Gizmo is an unknown quantity at this point
I think its a good idea to get an alignment. If it is off, getting it fixed will help tread wear and make driving a little easier. As far as where to get it, I dont know although I would not expect to pay more than $50 or so to get it aligned.
Old Mar 16, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
well depends where you go... if you have a camber kit, its gonna be a little more expensive to allign
Old Mar 16, 2003
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
for the front, the stock ones will allow u to adjust a little (but if your degree is off by lots then it still requires a kit), as for the rear, u need to get a kit for it...i lowered my car w/ eibach pro-kit and for some reason, both tires (passenger side) are really off, but the driver side is ok.
Old Mar 16, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
yes, definatly get an alignment after installing springs
Old Mar 16, 2003
Elite's Avatar
Elite is an unknown quantity at this point
Mine were fine until I installed GC and then my whole alignment went bad it cost me 65 bucks cuz it was so bad I had to hold the steering wheel to the side, its worth the 50 or so bucks in the long run. Newayz yes get the alignment.
Old Mar 16, 2003
Smartidiot's Avatar
Question
so.. are you guys refering to 50 dollars in CAD or US dollars?!?!
does anyone know where can i get a good job in Toronto area?!???!
Old Mar 17, 2003
VNlilMAN's Avatar
The Standard One
its always recommended you get an alignment anytime you lower the car..
alignment should cost no more then $55 USD
for a 1.3" drop you dont really need a camber kit..
"well depends where you go... if you have a camber kit, its gonna be a little more expensive to allign"
it shouldnt, if they charge more your just getting ****ed.. camber is part of alignment and it should have already been included in the price of the alignment...
Old Mar 17, 2003
Smartidiot's Avatar
Thanks for all the advices!!!.. but I just asked this guy from the carshop today and he told me that it is useless to do the alignment since it cannot adjust the camber anywayz.....so........um.... i dunno. i am really confused.. why do people here all recommend me to do the alignment if it cant adjust anything..!??!!?
Old Mar 17, 2003
VNlilMAN's Avatar
The Standard One
camber isnt the only thing thats part of alignment..
toe and caster is also part of alignment and those are also effected when you install lowering springs. that is why it is recommended you get an alignment.
even camber can be corrected to a slight degree without a camber kit. you dont need anything else besides stock parts to adjust toe and caster tho.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
