Help....need rear shock suggestions
Old Mar 12, 2003
Sidriver00's Avatar
Sidriver00 is an unknown quantity at this point
Ok hi guys i new here,names Mike I myself drive a 00 Civic si. But anyways on to the problem.........
Ok this is for my G/f car she has a 02 civic ex with ground control coilovers.. the thing is that here rear shocks are real weak and the right rear one i believe might be totaly craped out.... These new civics i dont know the after market world as well as the older honda aftermarket....
I did a search and didnt come up with anything good.....So if you will guys recomend me a good set of shocks front and rear but mainly rears........ all suggestions are welcomed and thanks in adavacne
i was thinking of some tokico illuninas (5-way) but didnt see them listed for the 01+ civics............
Please help guys..
Aim civicguy96
email sidriver2k@yahoo.com
Mike
Old Mar 12, 2003
Sidriver00's Avatar
O and sorry if this is a repost....... not used to these boars...i mainly post on www.clubsi.com
Old Mar 12, 2003
VNlilMAN's Avatar
The Standard One
thats cause only one out now are koni yellow inserts run about $550 shipped.
the rears are full replacements but the fronts you need to cut up your stock shock and use it's housing...
also in order to use koni's with gc's you need to get the adapters, you might be able to get them from the people you got your gc's from, the people your going to get your koni's from or directly from gc...
please search for more info
-locked-
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Makeice3498
Jul 2, 2015 11:13 AM
cmart1209
May 29, 2015 04:52 AM
vtec_concept
May 24, 2015 10:27 AM
Thees1
Apr 14, 2015 08:23 AM
