question about suspension on 2dr coupes
Old Mar 5, 2003
R3DL1N3's Avatar
do we have independent rear wheel suspension or something like that? my friend keeps babbling about me having it because he says when i yank my E-brake and spin around he thinks it looks different or something than when he does his. someone tell me some i can give him a strait answer
Old Mar 5, 2003
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
I'm not terribly suspension wise, but I don't think we have an independent rear suspension. Someone correct me if I'm wrong.
Old Mar 5, 2003
skipbarber's Avatar
independent: wishbone. all four corners.
Old Mar 5, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
i thought we had mcpherson strut suspension(SP?).. allowing us to have flat rear floor
Old Mar 5, 2003
skipbarber's Avatar
macpherson struts are the dampening components, the suspension type is independent..
Old Mar 5, 2003
PESTLNC's Avatar
Quote
[hr]Originally posted by: SkipBarber
independent: wishbone. all four corners.[hr]
Again plead my ignorance, but Honda clearly advertised the 7th gen as wishbone in the rear and McPhearson up front. Previous gens were wishbone front and rear.
Old Mar 5, 2003
skipbarber's Avatar
Quote
[hr]Originally posted by: PESTLNC
Quote
Again plead my ignorance, but Honda clearly advertised the 7th gen as wishbone in the rear and McPhearson up front. Previous gens were wishbone front and rear.[hr]
you know what, youre right. but its still independent suspension
Old Mar 6, 2003
VNlilMAN's Avatar
The Standard One
ya its still all independent.. aren't all compact cars independent? its just that most SUVs arent
Old Mar 6, 2003
skipbarber's Avatar
surprisingly not all compacts are independent. pretty much the only thing you wont see on a compact is leaf spring.
Old Mar 6, 2003
flotsamm's Avatar
Actually leaf springs were common on older compact cars that RWD.
Old Mar 6, 2003
Grey's Avatar
DIY King
BTW, independent suspension basically means that each wheel can more up and down independently from the other wheels. A sway bar makes our independent suspension more dependent. LOL Maybe your friend was referring to that fact? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 7, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
On our cars, we have independant suspension on all four wheels.
The opposite would be using a solid rear axle, such as on a truck. And yes, we have McPherson struts up front and wishbone suspension in the rear. The best setup is a double wishbone suspension, as in the 6th generation cars. Ours use a strut system to save space, as they are more compact. The advantage is that an independant suspension allows the wheels to stay parallel and keep more of the tire's contact surface on the ground.
A sway bar does not make a suspension dependant. The wheels still stay parallel, though the sway bar keeps the car more level by using the forces of the other shock to level everything out.
Old Mar 7, 2003
Weaponx12o's Avatar
Quote
[hr]Originally posted by: rickinthescv
A sway bar does not make a suspension dependant. The wheels still stay parallel, though the sway bar keeps the car more level by using the forces of the other shock to level everything out.[hr]
well said
Old Mar 8, 2003
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: Weaponx12o
Quote
well said [hr]
If you knew what I know then you'de say... Not really. I don't have the time to explain though. [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
That is unless someone asks me to...
Old Mar 10, 2003
VNlilMAN's Avatar
The Standard One
grey please explain . i can always learn more from you..
double wishbone isn't always the best. true mcpherson strut is a pain in the *** to modify cause of the steering arm but truth is, its probably the best in suspension. even m3's uses mcpherson struts..
Old Mar 10, 2003
Grey's Avatar
DIY King
Okay, well...
rickinthescv said, "The advantage is that an independant suspension allows the wheels to stay parallel and keep more of the tire's contact surface on the ground."
This is not true. An independent suspension simply means that each wheel move independently from the others. I.E. when one wheel goes up, the other wheels aren't affected at all. A stabilizer bar (AKA sway bar, AKA anti-roll bar) ties a set of wheels together (front or rear) and makes it so that it's less independent since now when one wheel moves up or down the other will do the same to a certain degree.
Anyway, a double wishbown suspension can indeed keep the wheels parrallel to the ground. However, this requires that the pivot points are in the same vertical plane. If they are not, then the wheels will still camber when the car is raised or lowered (or during cornering). The 6th generation Civics have a double wishbone suspension, but the pivot points are not in the same plane. That is why they still sell camber kits for 6th gen civics.
Old Mar 10, 2003
slikor's Avatar
slikor is an unknown quantity at this point
Well said Grey.
Just to clear this up:
Independent Suspension
A term used to refer to any type of suspension system that allows each of the two wheels of a given axle to move up and down independently of each other.
MacPherson Strut
A suspension system that consists of a combination coil spring and shock absorber (referred to a Strut) in one compact unit at each wheel. With this "independent" suspension design, road shocks at one wheel are not transferred to the opposite wheel. MacPherson struts use fewer parts, meaning a reduction on weight and fewer elements that could wear out.
Strut
The main support member in a MacPherson suspension system. The strut also serves as the shock absorber.
Also, there are several compact cars these days with a solid rear axle such as Chevy Cavalier, Pontiac Sunfire, Kia Rio, Nissan Sentra, and I'm sure more that I forgot about. Also most mini vans have such a setup too, since most are front wheel drive too.
edspyhill09
Jun 12, 2016 02:45 PM
h4ldol
Jun 3, 2015 03:26 PM
reqy
Jun 1, 2015 07:05 AM
TonoAlpha
Apr 30, 2015 04:21 AM
oneheadlight
Apr 29, 2015 11:30 PM
