help steering wheel shakes when im in 4th gear around 85 km/h
Old Feb 25, 2003
Ant81's Avatar
Ant81 is an unknown quantity at this point
it started sunday all of a suden when i hit 4th gear my steering wheel shakes ? what can this be i just got the car in august its a 2002 Si coupe but in the 1,2,3 gear it doesn't shake?? what can it be
Old Feb 25, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
Might be your wheel alignment off. Have a wheel and suspension alignment bro that might solve the problem. But before gettign all that check your tire pressure after driving for like 5 minutes. Make sure it's above 32 or so.
Old Feb 25, 2003
VNlilMAN's Avatar
The Standard One
balancing, balancing, balancing... alignment can cause the steering wheel to shake but 90% of the time its balancing... maybe one of the weights fell off or something..
Old Feb 26, 2003
jwsisme's Avatar
jwsisme is an unknown quantity at this point
If your issue is only in 4th gear, go back to the dealer and have them take a look.
If it's still under warranty you shouldn't pay anything.
I have no idea what the actually problem is....
Old Feb 26, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
I had a problem with my car shaking around 60mph last week. I determined that it was the tire pressure. It had been really cold, and my tires were covered in snow, while sitting overnight. It only lasted until the tires were (what I thought to be) normal pressure or heated up. I haven't had a problem since...
Old Feb 26, 2003
Firewall's Avatar
Firewall is an unknown quantity at this point
When your car shakes like that, it's because you proably have snow inside your wheels.... either scrap the snow off, or go to a shop to get them to spray it off with a pressure washer
Old Mar 3, 2003
Fireal's Avatar
Fireal is an unknown quantity at this point
I had a problem like this when I put my stock wheels back on for winter. The centering rings that came with the rims I got were still on the rotors and caused the wheels to not sit evenly against the rotor and eventhough I had an alignment done and they told me they were barely off, I almost three-wheeled on the highway cuz one of the rear ones almost came off. If your steering wheel shakes I'd have it looked at emediately since its possible that even a cm off could cause one of your wheels to shake itself lose at high speeds.
conspiracy90
Jun 7, 2023 01:01 PM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
honda200192
Suspension
Oct 27, 2019 12:23 PM
anddrrey
May 11, 2015 02:30 PM
RickyRocket
Nov 30, 2001 10:14 AM
