Why the wheelwell gap difference between 2 sides?
Old Feb 13, 2003
Karateman's Avatar
Karateman is an unknown quantity at this point
Just lowered my '01 Si by 1.3" with H&R Sport springs and my right rear gap is almost 1/2" higher than the left rear and the suspension shop tells me that's normal 'cause the cars aren't built perfectly. Do you believe this theory? Should I worry about it?
My car was never in an accident either. Furthermore, this 1/2" gap existed before the H&R's were installed as we had measured the before and after results. Weird.
Any ideas as to why? Anyone else have this problem?
Old Feb 13, 2003
666's Avatar
666
666 is an unknown quantity at this point
Mine was like that but it went away after a week or two, after the springs settled a little.
Old Feb 14, 2003
flotsamm's Avatar
Actually its normal, in fact theres a TSB that states that a little leaning to the left is okay since the left side is heavier. I have a 1/4" difference between my left and right side.
Old Feb 14, 2003
Karateman's Avatar
I just came back home from the Honda dealer for a 4 wheel alignment after dropping the suspension. Turns out the camber is 2mm out all around with a 1.3" drop. Anyway, I had asked the service advisor about the 1/4" difference between the L and R sides at the rear and they claim it's news to them. Just so happens, I brought my own measuring tape with me and measured 6 brand new Hondas (Civic Si, Civic sedan, Accord sedan, Accord coupe, Element, Prelude) and they were all out by 1/4" to 1" on either side. Usually the right rear was higher, except in one case.
I am content this is normal.
Thanks to all that responded to my thread.
Old Feb 14, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I just installed my tein's and its lower on the left side, I guess I just noticed it now since its dropped more... should I adjust my Tein's so it sits level or just leave it? will my tires where unevenly or what should I do! I don't want people to notice it and laugh at me.
Old Feb 14, 2003
VNlilMAN's Avatar
The Standard One
adjust it to the same height.. tire wear depends on toe, caster, camber, not the ride height. but remember ride height effects camber. so usually even ride height = even camber on both sides..
dinsum
May 28, 2015 09:30 PM
Youshoe
May 22, 2015 09:36 PM
leon1
Apr 28, 2015 07:32 PM
bsmiley
Apr 27, 2015 01:27 PM
CapYoda
Nov 11, 2001 05:17 PM
