Rattle on my B+G's
Old Feb 11, 2003
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
Rattle on my B+G's
I just got my B+G's installed about a week ago, when they were first installed they were as low as they could go. So obviously, I raised them some so that there is about a finger gap in the front and no gap in the back. Ever since, there is a rattle coming from the front right and I was wondering if anyone knew what the problem could be? thanks in advance.
Old Feb 11, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
Check all the bolts? Did they align your car after installed? Maybe camber is off also!
Old Feb 11, 2003
Weaponx12o's Avatar
its probably the bolts or something might be hitting against them. i don't think its the camber since there is no need for a camber kit on the front. if it's not the bolts you should get them inspected.
Old Feb 11, 2003
VNlilMAN's Avatar
The Standard One
are you sure you tightened the bottom perch right?
you get the noise when driving over badd road right?
most of the time it comes from the bottom or top perch, where the spring sits. a couple of people with B&Gs had problems with the rear rattling.. i think they greased up all the parts and it stopped the rattles.. you could always add spring isolators.
but ya check the bolts, people also forget to tighten down the bolt under the hood that holds the whole strut assembly in place. i dont think this is the case but worth trying
Old Feb 12, 2003
sc1golfr's Avatar
what exactly are spring isolators and where can i get them? are they hard to install or anything? thanks
Old Feb 13, 2003
VNlilMAN's Avatar
The Standard One
well just to let you know, alot of people disagree with using spring isolators. reason being, you paid 1000 for a suspension, it should be trouble free already.. try calling b&g and see what they say..
if i was in your shoe's i would probably just live with it cause its not really doing any damage, just annoying. or if it got to me i'd just use spring isolators..
but ya not sure where you could find them tho, sorry. i just know energy suspension makes them, its basically just a rubber tubing that goes around the springs so that metal doesnt hit metal. it would require you to take apart your suspension again.
oh didnt ask yet, did you get it done by a shop? cause i'd take it back to them, let them worry about it.
Old Feb 13, 2003
sc1golfr's Avatar
yes i did have them installed at a shop. i lowered the front a little today to get it to the right height and sprayed silicone spray all over it. ive driven it a few times and the rattling is not nearly as severe, very rarely does it anymore, but im still gonna take it in and get it checked, thanks everyone
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
Yazan93
Jul 14, 2015 08:56 PM
