How can I tell if an aftermarket suspension is adjustable?
Old Feb 10, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
ok... here's the deal. be forwarned... I don't know poo about aftermarket suspension.
I'm looking at a 98 GTI and it's lowered... a lot. The thing barely makes it over speed bumps. In MD the car cannot be lowered in order to pass inspection. What I need to know is how I can tell if the suspension is adjustable (i'm assuming that means i can raise the car back to it's original height without replacing the suspension). I took it to a garage to be looked at today and when they jacked it up I got a look at everything and all I could really tell was that it has big red springs.. (big help right?) Anybody have any idea how i can figure this out?
Old Feb 11, 2003
VNlilMAN's Avatar
The Standard One
they all have one thing in common, they all have springs...
here's just plain lowering springs
now here's sleeved coilovers
you see the red sleeve with the gold ring... the gold ring is turned and it goes up/down adjusting the height(since the spring sits on that ring). these go over your current shocks..
now here's true coilovers
its similar to sleeved coilovers except it comes with its own built in shock. obviously the green thing is the shock, the silver ring(kinda hard to see) on the shock body is the things that is turned to adjust the height.
so ya you could tell if the suspension adjustable by looking for that sleeve/threaded shock body/ring
Old Feb 11, 2003
JohnDoe's Avatar
thanks a bunch dude!
EdGasket
40
Nov 27, 2015 11:11 AM
naokigoffi
Aug 30, 2015 06:19 PM
Strycker
Aug 2, 2015 08:40 PM
JKWood
Jul 28, 2015 03:45 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
