KONIS
Old Dec 12, 2002
wizawaza's Avatar
wizawaza is an unknown quantity at this point
KONIS
Just ordered konis, is it hard to do the front installs? Cutting the olds ones and everything, is there another diy besides the one, if not is that a good one to follow. i am goign to do this with my mechanic, he is not into all this, just and ordinary mechanic, think it is possible for him to do it?
Old Dec 13, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
Quote
[hr]Originally posted by: wizawaza
Just ordered konis, is it hard to do the front installs? Cutting the olds ones and everything, is there another diy besides the one, if not is that a good one to follow. i am goign to do this with my mechanic, he is not into all this, just and ordinary mechanic, think it is possible for him to do it?[hr]
Yeah man. Don't be intimidated by the cutting. Just be precise and make sure you follow the measurements. I paid about $550 to install my konis and my springs and I wish I hadn't because looking more closely now I realize I could have done that job EASILY. You just need the proper tools. Those tools aren't hard to get either, nor are they expensive.
Old Dec 13, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
If you are timid, have it done. Thats just my .02$
But if you think you can, then go for it. Ill be proud[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 13, 2002
666's Avatar
666
666 is an unknown quantity at this point
It's not that hard as long as you take your time. My instructions did'nt have any words, just pictures. That's the only part that really sucks.
Old Dec 13, 2002
Bartkat's Avatar
It's not that hard to do. Just measure and cut. I found that using a tubing cutter is better than using a hacksaw as it give a nice smooth square cut. The mechanic sure ought to know how to use a spring compressor and do the install, that's pretty standard.
Old Dec 14, 2002
Frank2sy's Avatar
Frank2sy is an unknown quantity at this point
What size of drill bits are required to drill the hole on the bottom of the strut housing?
Old Dec 14, 2002
Bartkat's Avatar
I used 37/64 " bit. I believe the instructions call for 14mm. It's a thru hole for the attaching bolt with washer, so it can be a little oversize. You need a good solid clamp to hold the strut and a drill press as it's a little tough to drill. It also helps to have a good quality bit.
Also one needs to make sure to drill a small hole before cutting the top of the shock, because the oil inside is under nitrogen pressure. You want to bleed off that pressure before you cut or it makes oil spray mess.
I would also recommend that before putting the inserts in the struts, to put some paint on the cut edges and edges of the drilled holes so they won't get rusty later on.
Old Dec 22, 2002
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
can someone tell me a website where i can get the konis?
Old Dec 22, 2002
AznHalfy's Avatar
AznHalfy is an unknown quantity at this point
www.tornactive.com .... ($555 for coupe model ... $535 for sedan)
Old Dec 22, 2002
nytejade's Avatar
That's odd. Why do they seem to be getting MORE expensive instead of LESS? People must be buying them like hot cakes or something.
Demand(up)
Supply(down)
Price(up)
Old Dec 22, 2002
Bartkat's Avatar
I paid $515 plus $25 shipping for mine from Import Horizon in late Februrary, 2002. That's $540 shipped for coupe.
Import Horizon price as of their website today is $531 plus shipping, which would now be $556 shipped or $1 more than Tornactive.
Pricess apear to have gone up all over.
Old Dec 23, 2002
Lasher's Avatar
Lasher is an unknown quantity at this point
Can any one tell me the difference between Konis for coupe or for Sedan
Old Dec 23, 2002
Bartkat's Avatar
I think on at least the 01 models, the sedan and coupes have different rear spring heights.
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
cukaracha
Aug 29, 2015 05:27 PM
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
