Alignment results
ThE CoRRupToR
Alignment results
Here are my alignment results from lowering the car. Im not really sure cuz I've been hearing different stories that my tires wont wear out with these specs. But maybe you guys can answer it. Should I take it back to them so they can realign them?
Left front Right front
Actual/Before Actual/Before
-0.1/0.1..............................(camber)......... .....................-0.7/-0.8
0.03/-1.64.............................(Toe)............ .....................-0.02/1.74
FRONT
Actual/Before
0.5/0.9................................Cross camber
0.01/0.10............................Total Toe
Left Rear Right rear
-0.5/-2.4..............................(Camber)......... ...................-0.6/-2.4
0.07/0.05................................(Toe)......... ......................0.08/0.02
REAR
Actual/Before
0.15/0.07.............................Total Toe
-0.00/0.02............................Thrust angle
FRONT
Actual/Before
REAR
Actual/Before
The Standard One
sounds about right.. but i would have to double check with what the specs are... it doesnt say on the alignment sheet does it?
well except for the front right.. kinda sounds off... i think it should be in the -.5 to +.5 range
well... here's what i have on my report sheet that shows what the numbers are supposed to be around.
FRONT...
specified range:
camber: -.8 to .8
toe: -.06" to .06"
REAR...
specified range:
camber: -1.5 to 0
toe: .02" to .08"
FRONT...
specified range:
camber: -.8 to .8
toe: -.06" to .06"
REAR...
specified range:
camber: -1.5 to 0
toe: .02" to .08"
Munzy
21
Oct 7, 2015 07:48 AM
raymondxcho
Sep 29, 2015 09:00 PM
TheRiddicles
Sep 21, 2015 01:28 AM
