What kind of full coil-overs are available
Old Dec 10, 2002
Firewall's Avatar
Firewall is an unknown quantity at this point
I checked the parts section, but since TEIN SS aren't even there, I figured there are some missing. So I was wondering what are the different full coil-overs available for our cars? So far I have the following
TEIN SS
NEX SR
H&R
KW coilover variant 1's
Intrax
any other one's?
Old Dec 10, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
JIC-Magic FLT-A2s
Tien FLEX
Any full coilover setup that will work with the new Si hatchback or the RSX will fit our cars as well. Use that to your advantage.
Old Dec 10, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
B+G
Old Dec 10, 2002
SoNiCcIvIc's Avatar
Quote
[hr]Originally posted by: Mex
B+G [hr]
FLT-A2s own B&Gs. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 10, 2002
CarbonFly's Avatar
Quote
[hr]Originally posted by: SoNiCcIvIc
Quote
B+G [hr]
FLT-A2s own B&Gs. [IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
I've never even heard of those..........i'll stick with Tein or B+G.
Old Dec 10, 2002
Firewall's Avatar
Do you guys know the approximate prices?!? I don't want something that will cost me too too much, but I don't want a cheap sleeved coil-over system either. And also, if you would know the maximum drop, that would be great...
Old Dec 11, 2002
EM2Evolution's Avatar
EM2Evolution is an unknown quantity at this point
I agree...JIC-Magics
Old Dec 11, 2002
Mex's Avatar
Mex
JIC Magic's are full coilovers? what's the cost? and how much of a drop do they give ya?
Old Dec 11, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: FlyRiceRacer02
I've never even heard of those..........i'll stick with Tein or B+G.[hr]
your trippin.. just because you never heard of them, your going with tein and b&g??? Jic has to be the best coilovers. not only can you adjust the dampers but you can also control the spring load/spring rate. you also adjust the shock body rather then just the spring perch. why is this better... when you adjust only the spring perch, your changing the springs preload and also shortening the stroke. when you adjust the shock body, you keep a full stroke. since you have an adjustable body, you dont adjust the spring perch to lower/raise the car. you adjust it to change the spring rate.
JIC-Magic FLT-A2s arent cheap and they arent cheap for a reason. they run about 1600. best coilovers IMO.
Old Dec 11, 2002
CarbonFly's Avatar
Quote
[hr]Originally posted by: VNlilMAN
Quote
JIC-Magic FLT-A2s arent cheap and they arent cheap for a reason. they run about 1600. best coilovers IMO.[hr]
Let's see if this makes sense to you........why would I put my word behind a coil that I have never heard of, seen, or ridden on. I am going to give my advice on what I do know.
I just said that I have never heard of them before. That doesn't mean that they aren't good. and I didn't say that they weren't good.
Got a webpage or something. Or name someone on here who has them?
Old Dec 11, 2002
VNlilMAN's Avatar
The Standard One
true.. maybe i should have came out differently.. i'm just trying to let you know theres other brands out there other then tein and B&Gs...
jiv flt-a2
no one here has them. probably cause they're so expensive and they dont make a specific one for our car. they make it for the rsx(if you want reviews a couple people at clubrsx.com have them). and i believe they're coming out with one for the SIs which should fit our cars. the our car and the SIs suspension is basically identicle(fitting wise). the rsx one probably would fit too but the SI is a closer match
Old Dec 11, 2002
CarbonFly's Avatar
Not to sound like an A$$ or try to flame....but they aren't out yet? or even made for our cars?
I don't know how on earth I am supposed to know about these coils when they don't exist.
I'm was trying to list the top ones that I knew of for OUR cars. We could talk about coils for other cars all day long that cost much more expensive.
I'm sorry dude, i'm kinda pissed now that it seemed from your wording that I was being called out and made to seem like an idiot about not knowing about some coils the don't even exist.
Let's just let this one die. I don't wanna **** of a mod or anything by saying anything else on this subject.
Old Dec 11, 2002
VNlilMAN's Avatar
The Standard One
its take alot to **** me off and dont worry you havnt yet. i dont care about having debates or even straight out arguments just as long as you dont act childish and you have so far...
i was only mentioning them cause a few people before me have mentioned it.
i dont mean to **** you off either and sorry i already have. there obviously has been some misunderstanding from both sides. theres no hard feelings here n hopefully its mutual with you.
Old Dec 11, 2002
CarbonFly's Avatar
We are cool, no hard feelings.
Old Jan 1, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Tein Flex!
A nice way to spend $1700. But if I had the money I would go with the Mugen Moton 22k/25k setup. But then I would not drive on the streets.
Old Jan 1, 2003
Zzyzx's Avatar
Autocross Junky
Quote
[hr]not only can you adjust the dampers but you can also control the spring load/spring rate. you also adjust the shock body rather then just the spring perch. [hr]
I hate to brake it to you FlyRiceRacer02, But the only way you can adjust Spring Rate is by changing the spring.
Old Jan 2, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
Quote
I think that was VNlilMAN that said that.
Old Jan 2, 2003
ASWZero's Avatar
Quote
[hr]Originally posted by: Zzyzx
Quote
[hr]
Yes, there is one way to adjust the spring rate. You can only do this when you compress the spring with the perches. So techniquely, the spring compress more than its unsprung length. A spring's rate is the rate with about 1/4 of inch compressed. The rate they give you is usually an average. When a normal spring is compressed the spring rate will change with the amount of compression. It is not a noticable difference, but then that is when progressive springs come into play. They have a noticable jump in rate with compression.
And it was VNlilMan that said that.
Old Jan 2, 2003
Zzyzx's Avatar
Autocross Junky
Sorry, my bad. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Jan 2, 2003
VNlilMAN's Avatar
The Standard One
yup, thats what i said and yup aswzero is correct. thats one major difference between tein ss and b&g vs. tein flex(haha thanks aswzero, learned something new) and JIC FLT-A2.
Old Apr 1, 2003
silver02civic's Avatar
silver02civic is an unknown quantity at this point
Just Talked to Kevin from JIC in Downey. ( whole sale )
ME: want to know if the JIC coil over system you have for the RSX type-s will Fit a 2001 and UP Civic
Kevin : Actually our kit now includes all the necessary parts for a successful swap
witch would be RSX tie rod ends, and different mount brackets for the rear shock.
before you would have to Shave 2 MM off the Mounting assembly
now we include a bracket that will fill the civic.
so that's what you have to do, and yes they are NOT cheap
talked to xs-engineering.com ( referred Kevin )
they quoted me $ 2050.00
also to throw a little some thing ells in
asked him about custom turbo for the 2001- civic
stated that they are working on one for the APC car
but No HP # as of yet and no release date.
alxz310
Jul 30, 2015 12:18 PM
Misfit2613
Jul 30, 2015 09:49 AM
Jul 14, 2015 03:39 PM
NoobyKid
Jul 13, 2015 07:53 AM
chrisjackson321
Jul 12, 2015 03:00 PM
