Yet Another RSX anti-sway bar conversion happy driver
Old Dec 7, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Just finished installing the rear RSX anti-sway bar.
Cost: $50 w/ bushings (from a member of clubrsx.com)
Time: 1 hour
Definetely feel a MAJOR difference. It was nearly impossible to take out the bolts from the endlinks... i must have sprayed the entire WD40 can (lol).
Some things i just wanted to say
You don't need the RSX bushings! They are almost identical to our stock ones....soooooo my point is just get the BAR and you'll be fine!
2nd thing... Make SURE you use Jackstands. You'll be putting so much force to get the bolt from the endlinks that your car will start shaking.
eh...that's about it. Worth the money, keeps the back of the car glued to the ground. Quite amazing what a 19mm anti-sway bar can do in a civic.
Direct bolt-on for 01+ EX , 02+ LX
Others require drilling.
-ak
Old Dec 7, 2002
KeNsHiN's Avatar
LEVA
Old Dec 7, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
awesome, make some difference doesnt it?[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 7, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
definitely...did mine as well. I recommend it as well. However, I would get the bushings with the bar if you can. It will fit better. I got mine for $50 from ClubRSX also, but the guy gae me the bushings with it.
Old Dec 7, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
Now it's time to upgrade to the Progress 22MM bar! : )
Heheh just kidding. Congrats, and drive safely. Watch for oversteer.
Old Dec 8, 2002
sumama's Avatar
sumama is an unknown quantity at this point
I think the 19mm rsx sway bar is the best for our cars. 22mm is just too big, and you have to get a lower tie bar. I just have a bad feeling about 22mm, too big and might mess up ur rear suspension.
Old Dec 8, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I have the 22mm rear progress bar and its fine, I don't know how you got a bad feeling.. anyways it comes with the rear lower tie bar and it feels great around turns.. It has a neutral feeling most of the time and a push at its limits....
Oh and I think you need new bushings no matter what size bar you change to because if the bar is different size than the bushing is going to be a different size too.... the stock bar was so small (size of a pencil) I don't see how those bushings would work with a bigger bar!
Old Dec 8, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
I know alot of the members of the boards say the rear sway bar is a great mod and I will most likely do it, but isn't the front sway bar usually supposed to be larger than the rear? I heard that somewhere and I wanted to see if anyone knew. The deal was if the rear is too large then it promotes over/understeer (I forget) Just wondering...
Actually I just looked up a few specs on other 2003 Hondas...
front/rear bar dia.
S2000 27.2/28.6
Accord 25.4 / 14.0 (coupe)
Civic Si 25.4 / 15.0
Pilot 23.0 / 20.0
Civic 15.9 / 12.0 (coupe)
So, every car except the S2000 has a larger front bar than rear. If I remember correctly the S2000 has a near 50/50 weight distribution, so maybe that is another factor in matching the sway bars to the car. Anyways, I was just thinking about it. Lemme know if I'm right or way off... Thanks.
Also, has anyone added a larger front sway bar as well?
Old Dec 8, 2002
ak's Avatar
ak
Retired Mod
so i went on a canyon run today and DAMN!!!
The back stays 100% glued! It's hard to lose control of the car. I took 20mph turns at 60mph and still stable!
this mod
Old Dec 8, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: ak
this mod [hr]
What tires/shocks/springs do you have?
Old Dec 8, 2002
ak's Avatar
ak
Retired Mod
My tires are not even great.
VISA tires (Made in Japan)
Sprint 2" springs (looks more like 1.5")
Stock non-blown shocks
Old Dec 8, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
Quote
You don't need the RSX bushings! They are almost identical to our stock ones....soooooo my point is just get the BAR and you'll be fine! [hr]
because the bar is thicker, you are going to need new bushings. the hole on our stock bushings is only 12mm in diameter. you'll need one that's 19mm. all you need is the bar and the bushings
GolNat
Suspension DIY
May 12, 2022 06:49 AM
STYLIN2K2
Jan 1, 2002 03:47 PM
supercivic01
South
Nov 30, 2001 11:27 AM
