Stiffness
Old Nov 28, 2002
DizWikedCivic's Avatar
Stiffness
what steering wheels got stiff when i install skunk2 coilovers and new rims. i have 205/40/17 in the front. and my maintenece light goes on. is my tires properly balance right. or what is the problem
Old Nov 29, 2002
VNlilMAN's Avatar
The Standard One
i remember my steering feeling a little different but not sure if it was stiffer...
maintence light probably isnt cause by the wheels or dropping. did you reach the 10k mile mark? or maybe the gas cap isnt tight enough? my tires were misaligned and i never got that light. i see no reason for it to either
Old Nov 29, 2002
i havent reach 10k, yet i got like 8k on my car, gas cap? the oil cap or the gas cap by the trunk? what would i need to change or inspected when i reached 10k
Old Nov 29, 2002
flotsamm's Avatar
You gotta make sure the gas cap is closed atleast three clicks or the maintenance light will flash. For 10K maintenance, check out what the manual says.
Old Nov 29, 2002
VNlilMAN's Avatar
The Standard One
at 8k, the light will blink 3 times everytime you turn on the car. at 10k it'll stay on... it says it in the manual, tells you how to turn it off too
Old Nov 29, 2002
u know what pg does it say on the owern maunal. i have 2002 owner manual
Old Nov 30, 2002
o nevermind, i found out how to turn off the maintence light. is my steering wheel getting stiff cuz my alignment or powersteering cuz when i drive and let go of steering wheel it goes to the rights
Old Nov 30, 2002
VNlilMAN's Avatar
The Standard One
ya thats because of alignment.. anytime you lower your car, you should get your car aligned
Old Dec 1, 2002
TuffVietta's Avatar
TuffVietta should not be trusted
i have skunk2 coilovers and i also noticed that the steering wheel felt a LOT stiffer afterwards whenever i turned, but i guess u just have to used to it
Old Dec 2, 2002
816CvC's Avatar
816CvC is an unknown quantity at this point
my steering wheel never got stiffer but i did hear a noise coming from my coilovers. i think it's either rubbing or something isn't as tight as it should be. i know that my left front strut rattles now. i think it's a loose bolt when i did my koni install. gonna get it looked at first thing monday.
Old Dec 6, 2002
IonRays's Avatar
IonRays is an unknown quantity at this point
my maintainance light went off @ 8K..i dont think its your skunks c/o or new rims
i drive
Sep 14, 2015 01:56 PM
fordover
Jul 11, 2015 09:10 PM
Grey
May 29, 2003 09:43 PM
CapYoda
Dec 3, 2002 11:06 AM
Kill
May 15, 2002 12:03 AM
