Question on Koni Yellow
Old Nov 11, 2002
are6's Avatar
are6 is on a distinguished road
Just curious...do the koni yellows for the EX Coupe have the adjustable spring perches? I've been checking around and been reading that "selected applications" have the adjustable spring perches. Would we be that lucky to get the Civic models to have this?
Old Nov 11, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
The rear's allow you different height selections...
Old Nov 11, 2002
VNlilMAN's Avatar
The Standard One
but they dont have adjustable spring perches...
from my understanding, yes you could "adjust" the height but this is just placing the spring in different ways and not the actual perch being able to be adjusted... please correct me if i'm wrong. and if i am, can someone please post a pic of the rear so that i can understand.
Old Nov 11, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: VNlilMAN
from my understanding, yes you could "adjust" the height but this is just placing the spring in different ways and not the actual perch being able to be adjusted... please correct me if i'm wrong. and if i am, can someone please post a pic of the rear so that i can understand.[hr]
There are locating rings on the rear shocks. You set the height on installation based on the load on the rear of the car. Most times is should be set on the "normal". There is no height adjustment once the shocks are on the car.
You do, however have the dampening adjustment on both the front and rear shocks.
Check my members rides pics to see the ride height with Eibach ProKit and Koni Yellows. This, of course is looking a bit lower due to the OEM body kit.
Old Nov 11, 2002
VNlilMAN's Avatar
The Standard One
how much can you raise/lower the rear with this?
Old Nov 11, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
If you call up Koni they will custom make you struts. It does not cost an arm and a leg. It should take another hundred from your pocket. They also sell adjustable spring perches that fit on their struts. I know GC uses Koni or Bilstein for their shocks(its one or the other).
Old Dec 18, 2003
Erichyung's Avatar
Erichyung is an unknown quantity at this point
nice.. i should check my ride height
alinaray
18
Aug 24, 2015 01:04 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
sch2cm
Jul 21, 2015 09:58 PM
Causemo
Jul 5, 2015 06:42 AM
