INSTALLING KONIS NEED HELP!!!! HURRY
Old Oct 18, 2002
badcivic2002's Avatar
badcivic2002 is an unknown quantity at this point
I am in the middle of installing Goldlines and Koni Yellow shocks. In the instructions for the konis it says to cut the front strut out. So I did but when we cut it to the measured length the koni goes in but hits a flange and does not go in far enough for the end to be avail for the bolt at the other end. WHAT DO I DO. Do i cut it more? Did I get the wrong shock? HELP PLEASE[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 19, 2002
mohawkboom's Avatar
how much is the difference?.. if it's a matter of a mm or so cut it more..if it's way off...welll hmmm
Old Oct 19, 2002
VNlilMAN's Avatar
The Standard One
bartkat should know.. but ya i think the koni instructions were off. said to cut a little when you had to cut alot...
Old Oct 20, 2002
Yeah... I said F it and cut em up.
To get them to fit I had to cut almost 2in total. Well they fit and rides NIIICE with koni and goldines.
All in all it took 10 hrs.
Old Oct 20, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
The koni's have to be pressed, or hammered, in to the stock housing. They have those little bumps on them that are designed 'squeeze' into the stock housing. It was scary getting them in, but they are designed like that to keep them aligned correctly in the housing.
Old Oct 21, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
They don't have to be necessarily pressed in, check out my install guide at:
http://www.7thgencivic.com/forum/mes...ighlight_key=y
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
