how low to go???
Old Oct 14, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
how low to go???
I have 215/45/17's on a 01 civic ex. I am installing my coilovers, and utalizing the stock struts. What is the lowest drop I can go WITHOUT having to put on a camber kit or new struts??? It is my understanding that if you drop too much you need a camber kit and could blow your stock struts. I may replace the struts and install a camber kit down the road, but for right now no more $$$$, so I just want to go as low as I can without stressing the struts past what they would be stock, nor ruin my tires due to negative camber.
thanks for the advice!!
Old Oct 14, 2002
Desi's Avatar
Desi is an unknown quantity at this point
here's my advice: go as low as you wanna go.
as for camber: camber will always be messed up if you lower a car. the lower you go, the more negative or worse a camber gets.
stock strut/shocks: as long as you don't drive like an idiot (i.e jumping speedbumps/potholes, or taking sharp turnsat 30-40mph, you wont need to get aftermarket ones. but there a good buy down the road.
here my drop: tanabe springs 2" drop. camber is obvious, worse in the rear wheels. i have had these for 1 year and my stock struts/shocks are fine. my tires aren't wearing down unevenly YET. but the tires in the back should wear down unevely faster in the back b/c of the negative camber.
but i fix my rear camber in $3. so my problems are fix.
Old Oct 14, 2002
VNlilMAN's Avatar
The Standard One
suspension FAQ
desi basically summed it up tho
-locked-
CraigW
Aug 18, 2015 07:06 AM
jwalkerck1
Aug 17, 2015 10:03 PM
JetsterDajet
Aug 16, 2015 01:56 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
alxz310
Jul 30, 2015 12:18 PM
