Best way too...
Old Oct 9, 2002
RollOut's Avatar
RollOut is an unknown quantity at this point
Best way too...
Sup, im looking into lowering my car and was woundering what the best way to do it would be...
peace
Old Oct 9, 2002
DarkCivic's Avatar
DarkCivic is an unknown quantity at this point
Put 500lbs. of cement in your trunk, then use the search feature.
Old Oct 9, 2002
aZnVoYCe's Avatar
Quote
[hr]Originally posted by: DarkCivic
Put 500lbs. of cement in your trunk, then use the search feature.[hr]
[IMG]i/expressions/laugh2.gif[/IMG]
Honestly, get TRUE coil-overs. Not sleeve coil-overs. But that cost $$$. If you want a cheap way non-adustable go for Goldline or Eibach springs with Koni struts or Tokico if they do come out. If you want adjustable then go for Ground Controls or Skunk2 with Koni or Tokico shocks. Hope this helps.
Old Oct 9, 2002
VNlilMAN's Avatar
The Standard One
suspension FAQ
best way, as aznvoice has said, true coilovers. also camber kit and alignment.
its going to run about 1200-1300 total tho.
too expensive... get springs, i recommened neuspeed(either race or sport depending on preference). konis, camber kit, aligment... should run about $800-$900
still too expensive...just neuspeed with camber kit and alignment $300
still too expensive...neuspeed $140 <--- what i did
Old Oct 11, 2002
RollOut's Avatar
THx for the info VNlilMAN
aZnVoYCe
Dawit Melese
Sep 11, 2015 08:25 PM
mrohitredd
May 28, 2015 10:03 AM
CapYoda
17
Apr 8, 2004 07:50 PM
dret
Canada West
15
Dec 21, 2002 04:15 AM
CapYoda
Sep 8, 2002 04:07 PM
