goldlines+ 18's anyone with pics
i have 225/40/18 on konig toxxins i was wanting to see the drop on someones car before i buy i want to get goldlines if they wont be to low sportlines if they are
The Standard One
it actually depends on the tire size not only the rim size. 225-40-18 is kinda thick/wide and it might rub... i have 215-40-18 on neuspeed sports(very similar drop to goldlines) and i have no problems... my car looks stock height with only a 1 finger gap...
from what i've heard you should be fine even with 225-40-18.. might want to check the tire/wheel forum as well tho. or if you do rub you could always do what toretto do, gut out the fender wells.
Quote
[hr]Originally posted by: DarkCivic
Ray you have no pics! I want to see goldlines on 18 or 17 as well.[hr]
i measured a 1.75 gap in front and 2 in rear from the top of the fender, the back will fit fine with 4 inches it tucks, the front is what i worry about when i turn, and i also want the back to sit level or higher than the front and all the sportlines seem to sit low in the back
im running 215/35/18 on toxxins and neuspeed sport springs and it was a 1.75" drop up front and they are fine. my ride
i like yours spider sits nice and mine wont be much different do u like the ride, and where did u get them?
i think i might try to get them in dallas ill be there for hot import nights aug 3
VNlilman,
I have just installed the same combination of wheels/tires/springs (18" wheels, 215/40/18 tires, Neuspeed sport) but I have found that when I look at the car from the side, the rear appears to be sitting lower than the front. Did this happen with your car? Did it take a few weeks to settle?
It doesn't seem like my rear should be lower than the back because the springs are designed to lower the front more than the back and I have nothing in my trunk.
Any ideas?
Thanks,
Terry
Any ideas?
Thanks,
Terry
The Standard One
it only took a couple days to settle.. you should have like a 1" gap all around with those tires. how much fender gap do you have? you dont have a sedan do you? if its not due to wrong installation i'm sure neuspeed will replace the rear springs for you but then your going to have to reinstall them so...
ricer_em2
May 11, 2016 08:09 PM
TheRiddicles
Sep 21, 2015 03:34 PM
TheRiddicles
Sep 21, 2015 01:28 AM
