Update on squeaky newly-installed springs
Old Jul 25, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
As I've posted a while back, had rumbling/squeaking sound from my Sportline right after it was installed. When I had them out for installing Koni's today, surely the paint's scratched off big time on the bottom of the springs (as predicted by Eibach's engineer).
Anyway, especially on stock shocks, apparently, the springs will scrape the metal base. Solution was simple. Rubber tubbing. I'm not too sure what material, as the shop guy did it, but it was heavy duty (three times thicker than the rubber sleeve provided with the springs), and just 180 around the bottom end of the springs.
No more noise. Of course, 500% better ride with Koni's.
Old Jul 25, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
thats good to hear.....spread the word! a lot of people have this problem thanks for the help!
Old Jul 25, 2002
MSoft's Avatar
Yeah, the shop was quite nice and was gonna do the base for me without charge anyway, but I decided I'd like Koni's now too.
So they didn't charge my labour (for Koni's AND padding the base of the springs). 3 hours and 2 technicians.... I suppose I got my money's worth!
Old Jul 25, 2002
VNlilMAN's Avatar
The Standard One
this is probably why sparying wd-40 worked for a couple days... i'll probably try to grease it or something... but ya thanks for the info
Old Jul 25, 2002
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
Quote
[hr]Originally posted by: VNlilMAN
this is probably why sparying wd-40 worked for a couple days... i'll probably try to grease it or something... but ya thanks for the info[hr]
Very true... When my local shop put my Skunk 2 coil overs in I would have to put the grease on once a week on the top of the coil over because it was rubbing on the top of the strut. Both being metal it would squeek and very annoying but once they put a piece of rubber between them, I haven't had any problem since.
Old Jul 25, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
Can you put that vinyl fish tank tubing? I was thinking of doing that put my squeaks magically disappeared.
Old Jul 25, 2002
MSoft's Avatar
I'm not sure how much force it has to hold, but you want something that's not going go crack or break with time.
Old Jul 25, 2002
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
I've had my Goldlines on for a week and they havent squeaked the first time. I don't think i've heard about anyone else with goldlines squeaking either. Whats up with this??
Old Jul 25, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: 2k2civicRAY
I've had my Goldlines on for a week and they havent squeaked the first time. I don't think i've heard about anyone else with goldlines squeaking either. Whats up with this??[hr]
i think its mainly an installation issue. i'm not saying people with squeaky springs got them installed wrong but it isnt easy getting the springs to sit on the lower perch correctly... most of the time theres going to be some play...
Old Jul 25, 2002
Mbow's Avatar
I get some noise from mine as well. I would love to take them out and put the tubing on but all be d@mn if I am paying for another alignment.
Old Jul 25, 2002
VNlilMAN's Avatar
The Standard One
try using lithium grease, saw them using it on the diy, i'm sure that would help
Old Jul 26, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
yah my goldlines are going nice with no sounds at all that are abnormal that i think of......system is always pounding so i never hear anything anyways but goldlines are some nice springs for sure.
Old Jul 27, 2002
Machina's Avatar
Machina is an unknown quantity at this point
I have sportlines and no problems...if you didn't trim the bump stops you'd get that rumbling sound for sure...
UltraHDGames
Jun 8, 2016 05:16 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
speedlever
Sep 24, 2015 07:18 PM
