Koni Yellow's full front replacement out
Old Jul 18, 2002
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
I got a question for the forum readers. I stopped at the performance shop close to where I work to get prices on suspension parts. I specifically was inquiring about the Koni Yellows. I explained to the guy at the shop that you have to cut and drill the front strut housing to use the Koni's. He called one of his suppliers to inquire about the Koni's, since I was asking about the labor charge to get the housings cut. The shop had told me that I could get those, but that there are also full replacement strut and housings from Koni for our cars. I tried calling Koni, but got an answering machine. Anyone know about this, and any place I might be able to get them cheap. I got excellent prices from the shop(a little better than what Rob quoted me), but the full replacement Koni's seemed a little expensive.
Old Jul 18, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
that would be kew but i THINK it might be one of those 96-2001 civic things
Old Jul 18, 2002
Not sure. He checked with the dude to make sure it was for my 2002 LX. I double checked with the shop owner and he told me that they now have replacements for our fronts. I hope it's true. The price he gave me for them was more than what Rob had quoted me for the Koni's I'm assuming that it is true because the other parts I inquired about the shop beat Rob's prices without me even mentioning them. I pmed tornactive about it, and hoping Rob might know about them. I'll probably be ordering them from the shop tomorrow if my paycheck looks good enough. Hopefully it will though.
Anyone else know about these.
Old Jul 18, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Well, I can you one thing, they are probably out for the RSX. The good thing is the strut will fit our car and since the yellows are adjustable, I cannot see why we could not put them in a 7th gen.
Old Jul 19, 2002
Grey's Avatar
DIY King
Wow, sounds good. Finally a full replacement. Expensive though. Hopefully they were able to improve on the front strut assembly in some way as well (instead of just selling you an OEM spec assembly with their shock inserted).
Old Jul 19, 2002
TOOLOWCIVIC's Avatar
Why don't you just email koni to make sure. They usually answer your email pretty quick or give Rob a call. He should know if they're out yet. But yeah if the RSX struts fit maybe we can use their struts. They have more than just Konis out for them.
Old Jul 19, 2002
Mbow's Avatar
Hmm...a full replacement. I hope so. I am going to need some soon as it feels like my oe ones are gone. Please let us know.
Old Jul 19, 2002
I got a hold of Gordon at Koni North America Tech support. Talked to him for a little bit about them about the Koni's. He told me that there is no full replacement front for our civics(which everyone knows). I asked him about the RSX and he said they are not out yet, but even though the RSX and Civic are similar, there are little differences between the two. I can't wait to spend my half hour lunch talking to the shop owner by my work about this.
Old Jul 19, 2002
The shop confirmed today that there was no full replacement. [IMG]i/expressions/face-icon-small-sad.gif[/IMG] Got my hopes up for a few days though
Old Jul 19, 2002
Mbow's Avatar
Dog Blast it!!! You got my hopes up. I thought Tokico was supposed to be coming out with full replacements some time soon....
Old Jul 23, 2002
slikor's Avatar
slikor is an unknown quantity at this point
those bastards....gettin our hopes up for nothing[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
from my research on the similarities and differences between the RSX suspension and the 7thgen civic suspension, it seems to me like any front strut for the RSX would work in a 7thgen. this really dawned on me when i was browsing the Sept 02 SCC on page 127 (its an ad for JIC Magic) and saw a pic of their FLT-A2 full coilover for the RSX (i think its safe to assume its for the RSX anyway) and it looks just like the stock strut on our 7thgens as far as the mounting points, the steering control arm attachment point, and the other little peice of metal where i guess the ABS sensor wires go. i look at some tech drawings of both struts from the RSX and 7thgen and they look almost identical.
so it seems to me that one could use something like that coilover from JIC on a 7thgen, or anyother suspension components really that are for the RSX.
Old Jul 24, 2002
VNlilMAN's Avatar
The Standard One
i'm not sure if the rsx suspension will directly fit into our cars or not but just cause they look similar doesnt mean that it'll always work. even if they are a couple mm's off its not going to work right. most mcpherson struts probably look similar but doesn't necesarily mean that its going to all fit the same
Old Sep 5, 2002
Bartkat's Avatar
Cutting and drilling the OE strut housings is not hard to do. I'd invest in a tubing cutter and get a much better job than a hack saw. Access to a drill press helps for the mounting holes, but you can do it with a hand held electric drill. You can do that whole mod job in 15 min to a half hour with the right equipment. Be sure to polish the burrs of the the inside lip of the housings after you do the cutting. Stick the shocks into the housing, bolt and torque and you are ready to reinstall the struts on the car. Oh yeah, a really good spring compressor helps. My tire guy popped the springs off mine at no charge.
I have about 5000 miles on my ProKit with Koni yellows now and I just don't see how it could get any better for my driving style. (I like to go on twisty mountain roads as fast as my nerve will alow. The suspension can go faster than I will, I'm sure.
thesushiboy
Apr 12, 2015 02:54 AM
supercivic01
South
Nov 30, 2001 11:27 AM
CivicHX01
Nov 29, 2001 03:48 PM
SpoonSportsd17a
Nov 24, 2001 12:43 PM
