Front Koni Yellow cutting question? Koni instructions say to cut 7mm, but Honda Tuning instructions
Old Jul 31, 2002
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
Which is the correct measurement to cut? What did everyone else cut?
Old Jul 31, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
do u mean that drilling hole thing? well...thats waht i saw from the honda tuning....but we drill 10 mm for mine and it works just fine...the best for u to do is drill 7 mm and if it dont fit then 10mm then 40mm
Old Jul 31, 2002
The drilling part isn't what I was refering to, but thanks for that info, because the Koni instructions say that hole should be 14mm. If 10 works, I'm drilling 10mm(better safe than sorry). Dunno if you still have the Koni instructions, but I was refering to picture #4 where you measure from the top of the strut to cut with a hacksaw. The koni instructions look like it says to measure 7mm from the top then cut with a hacksaw. Honda Tuning says 40mm.
The 7mm doesn't make sense. Why cut 7/10 of a centimeter? I just want to make sure that you should actually cut 40mm.
Old Jul 31, 2002
CivicVTec's Avatar
oh that...yes...we cut 40mm off
Old Jul 31, 2002
Thanks. It was so odd to see 7mm on the Koni instructions. Guess I'll do this tomorrow night
Old Aug 1, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
There was a design revision. The earlier Koni's instructions said 40mm and the newer instructions say cut less. This was confirmed by Koni
Old Aug 1, 2002
Quote
[hr]Originally posted by: 3rdcivic
There was a design revision. The earlier Koni's instructions said 40mm and the newer instructions say cut less. This was confirmed by Koni[hr]
Why was the revision made? 7mm seems so small though.... compared to 40mm
Old Aug 2, 2002
Had a chance to call Koni today and the dude told me to measure the Koni from top of the strut to the yellow nubs, then subtract 7mm and that is your measurement to cut
Old Aug 6, 2002
Simkin's Avatar
Simkin is an unknown quantity at this point
14mm from the top sounds about right.
But what I noticed, when I finished everything, is that it really doesn't matter, as long as the nubs are covered....
I think koni wants them to be covered by atleast 7mm, and that's what they're trying to tell you in the directions.
If you want to know how to press them in after you cut everything, then you can check out my review:
http://www.7thgencivic.com/forum/mes...threadid=44383
Old Aug 7, 2002
TeamStylesRacing's Avatar
TeamStylesRacing is an unknown quantity at this point
what about the rubber bumpstops. i was talking to the shop and they said that in order to fit the konis in, they would have to remove the rubber bumpstops which was making my car bottom out a lot. but when i called koni up they said that it would fit. anyone know anything about that?
Old Aug 7, 2002
Simkin's Avatar
I left everything the way that it was, and have no problems. I use the eibach prokit springs, which is about a 1.5" drop. I didn't have to cut anything.
Old Sep 5, 2002
Bartkat's Avatar
I cut my strut housings 40 mm and also did the same for another guy's struts. They work fine.
Eibach says to cut some off the bump stops in the rear. I did that too.
The whole Prokit-Koni setup is really nice.
14mm works fine for the mounting bolt hole too. You have a large bolt head with a star washer that goes there. Just be sure to follow the torque specs. I checked mine after 1000 miles and there has been no loss of torque on those bolts.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
15
Aug 19, 2015 03:12 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
Lightman
15
Nov 8, 2001 05:06 PM
