Neuspeed Race springs problem
Old Jul 3, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
I searched but couldn't find...
I installed my springs and now the drivers side is about a half an inch lower than the other side. Any ideas of why this happend will help. Thanks!
Old Jul 3, 2002
VNlilMAN's Avatar
The Standard One
are you sure the springs are sitting on the upper mount right? maybe you forgot to put back the rubber peice on one of them
Old Jul 4, 2002
WishIWaitedForRSX's Avatar
WishIWaitedForRSX is an unknown quantity at this point
Same thing happened to my factory springs... Honda told me it's normal since the springs likely set to a single occupant drive (which I think sucks ***).
But it does seem weird for race springs, .5 inch'd be quite a lot... You should check the setup...
Old Jul 4, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: WishIWaitedForRSX
Same thing happened to my factory springs... Honda told me it's normal since the springs likely set to a single occupant drive (which I think sucks ***).[hr]
uh.. unless if you weigh like 500lbs i doubt it would be like that... it just seems like they're giving you the run around. and with race it is less likely to happen cause they use much stiffer springs then stock
Old Jul 6, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
I have the Neuspeed race springs for my coupe, 55.20.68 just checking if that's what I should have on the coupe? TIA.
Old Jul 7, 2002
VNlilMAN's Avatar
The Standard One
yup those are the right ones
GolNat
Suspension DIY
May 12, 2022 06:49 AM
reqy
Jun 1, 2015 07:05 AM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
JeffSpeed21
Nov 4, 2001 12:33 PM
