SPC and Ingalls difference
Old May 31, 2002
duyaknow's Avatar
duyaknow is an unknown quantity at this point
Okay, before I get flamed, it's not another typical question. I'm planning to drop about 2 inches with my new B&G coils (so happy, coming in a week), but i'm trying to buy a camber kit.
The rear I'm going to get Ingalls, but the front is for 75 bucks while the SPC front is 39. The only difference is that the SPC only adjust 1.75 degrees, while the Ingalls can adjust 2 degrees. I read on a thread that the front only need .3 degrees adjustment for neuspeed sport drop. But I'm making this new thread to make sure.
Plus if Grey is reading this, I read that you thought the Ingalls are poorly put together for the rear and that you had to take it apart and grease the threads and poly. I'm not worrying about the poly b/c i'm getting rubber, but I have to also lube the threads? You said you saw the SPC and they look better than Ingalls, but I have the problem with ABS bracket for the rear for EX Civics. Does the SPC have a mounting area for teh ABS. I also read in one thread that they do, but once again, trying to make sure before I purchase these off GBC.
Sorry for the long thread guys, always got alot to say and questions.
Old Jun 1, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
You should be ok with either....Hotchkis also makes a good kit. As for the appearance/lubing...small stuff, IMO.
Lightning Motorsports carries Ingalls and has these kits: front +/-1º for $23, front +/-2º for $46 and the rear -2º to +4º for $148.
Old Jun 2, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
I have the SPC rear kit, and yes they have a bracket, they are full billet steel ,and a little sturdier than the ingalls
Old Jun 2, 2002
01IncaPearl's Avatar
01IncaPearl is an unknown quantity at this point
Im getting the SPC front and rear. I compared the ingalls and the SPC and the SPC looks stronger and better made.
Old Jun 2, 2002
SQCivic's Avatar
SQCivic is an unknown quantity at this point
Ordered me a set of the SPC kits as well.
Old Jun 3, 2002
gipperkid's Avatar
gipperkid is an unknown quantity at this point
Hey where did you order your SPC camber kit from? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jun 5, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
Damn, i wish this post came out before i ordered my ingalls front and rear, i feel like i orderd garbage
Old Jun 8, 2002
duyaknow's Avatar
I got the Ingalls in the mail and don't worry about it. The ingalls is also made of steel and not of cheap plastic if that's what you might be thinking. A camber kit is a camber kit. Only difference is poly or urethane and amount of adjustment. Other than that, I doubt that your camber kit is going to be outperformed by SPC...haha. No horsepowers there man, but everyone knows what Ingalls is, so then you can tell ppl that and get props for getting name brand??? A confidence booster for you if your still feeling bad about getting ingalls instead of spc.
Tedverseti
Sep 29, 2015 05:41 PM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
