Simple alignment advice
Old 09-24-2015
meicalnissyen's Avatar
meicalnissyen has a spectacular aura aboutmeicalnissyen has a spectacular aura about
bought this 01 coupe as a DD
springs etc all OEM
LCA's were shot
pressed in front bushes, rears ok replaced struts,
BJ's meh
tie rod outers, meh
drove around the block to settle
ain't broke out my laser, just lookin,
I have mega front toe
and a good bit of rear camber
I generally prefer 0 and -0.5 on the rear and 1/16 out and -1.5 front on my speed for DD
whats reasonable on a Civic coupe?????
BTW, saw the struts an thought WTF, but, really kinda liking the straight shot steering rack geometry. actually like it a lot
Old 09-24-2015
Re: Simple alignment advice
0 toe front
+2mm toe in, rear
0*, +/- .75* camber front
-0.75*, +/- .75* camber rear
Caster, 1.5*, +/-1*
Old 09-24-2015
1.5?????
jeez, most speeds run 3ish stock, mine was shy, but with some hole elongation I hit 3.5
castor
Thanks for the specs brother
Originally Posted by ezone
0 toe front
+2mm toe in, rear
Caster, 1.5*, +/-1*
Old 09-24-2015
Those were specs from the book for an 01-02.
Later Civics upped the caster a smidge.
carid
09-28-2015 10:13 AM
2002ExCivic
22
09-28-2015 08:29 AM
General DIY
09-25-2015 08:02 PM
curaze
09-22-2015 08:27 AM
pilebuck13
09-21-2015 10:45 PM
Quick Reply: Simple alignment advice
