Front wheel studs
Old Jul 18, 2013
larryb73's Avatar
larryb73 is an unknown quantity at this point
Front wheel studs
Help!! I have an 01 and need to replace a front wheel stud. Does the hub have to have to be removed from the knuckle to get the old stud out and a new one in?
Old Jul 18, 2013
CraigW's Avatar
Re: Front wheel studs
Yes, I would do all 4 studs new at the same time.
Old Jul 18, 2013
larryb73's Avatar
I guess you need a press in order to separate the knuckle and hub. Can it be done without destroying the bearing?
Old Jul 18, 2013
CraigW's Avatar
Sorry, not a mechanic. Pretty sure if done correct... there will be no damage.
Maybe ezone will chime in.
I still find it hard to fathom why Honda continues to build them this way WHEEL STUDS BREAK, every other manufacture makes provisions to change them out easily.
Old Jul 18, 2013
larryb73's Avatar
Yes I agree this is going to very involved including involving a machine shop to press the bearing and hub in and out of the knuckle all for a $4 dollar stud!! CRAZY 😡
Old Jul 18, 2013
IF there is sufficient room, I just hammer them out and draw them in using a suitable nut and a stack of greased washers.
On the car.
Only disassemble what is absolutely necessary (speed is time, time is money!)
Sometimes the base of the stud has to be trimmed to get clearance......each situation is different.
Sometimes the knuckle has to be pulled and hub pressed.
It all depends on what there is to work with, I can't tell you about your car specifically.
Old Jul 19, 2013
larryb73's Avatar
I guess I'm the unlucky type. I removed the knuckle last night going to get hub/bearing pressed out today. I'm replacing control arm bushings while its apart the forward one is bad. Doing the other side control arm too while I am at it. This is going pretty good so far I got some good pointers from a buddy at work so that helped. I guess I'll have to deal with the intermittent lo-beam issue next week. Oh the life of a cheap skate hate to pay for something I can do myself.
Old Jul 19, 2013
CraigW's Avatar
On the low beams... I replied to your thread on them. Honda certainly needs to know that there fix is not working and should step up. There was also a 2nd recall, maybe you can get in on that ??
Did you get the column covers off ??
The defective/intermittent wire may be obvious by sight.
Old Jul 19, 2013
larryb73's Avatar
I have not had an opportunity to look at the headlight wiring yet. This wheel stud issue popped up so have been busy with that I am stopping by the Honda Dealer tomorrow to chat with them about head light issue after recall has been previously completed.
Old Jul 19, 2013
CraigW's Avatar
You can get a repair kit likely at a fair price but..... Getting those pins out of the housing takes some work for certain. And there safety recall failed to hold up.
Old Jul 19, 2013
larryb73's Avatar
I wonder if there is some sort of removal tool to release them?
Old Jul 19, 2013
CraigW's Avatar
Different connectors have different procedures.
Yes, there are removal/release tool sets available.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
edspyhill09
Jun 12, 2016 02:45 PM
elitezdc5
May 26, 2015 05:46 PM
bsmiley
Apr 27, 2015 01:27 PM
crazydragon
Nov 7, 2001 05:13 PM
