Rear Sway bar causing uneven wheel gap?
Old Apr 19, 2013
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
So I have lowered my car using lowering springs (neuspeed) and the passenger rear was 1" higher that the driver side (wheel gap) I had the SAME issue before I put in my new setup. I also had the same issue when I was dropped on coils but could compensate for it.
I disconnected the passenger side of the sway bar (19mm RSX) and the bounced the back a bit and it evened out....
How can I fix this so I can also run the sway bar! I have brand new stock endlinks.... any insight would be great.
Old Apr 19, 2013
Kennykid2002's Avatar
Kenny the Ricer
Re: Rear Sway bar causing uneven wheel gap?
Not sure what the problem would be.
I have the same 19mm sway bar and don't have that issue dropped on s techs.
Old Apr 19, 2013
TFMEX's Avatar
CO&CA
Everything is brand new, springs struts and all. It was the same issue with my stock struts... the more and more I think about it its been since I upgraded the rear sway....
Old Apr 19, 2013
krudmuphin's Avatar
That is really a bizarre issue. I can't think of how that could effect the stance in the rear... The sway bar should twist under the weight and sit quite evenly.
Maybe you just coincidentally got a set of uneven coilovers and uneven lowering springs, lol
Old Apr 19, 2013
TFMEX's Avatar
CO&CA
I know that's not the issue as when the sway is disconnected it sits fine... grrrr
I have traditionally tightened the sway prior to lowering the cars weight on the suspension... I have been reading about that causing preload on the sway bar, causing pulling to one side. Anyone have any input on this? is it true?
Old Apr 19, 2013
krudmuphin's Avatar
Now that you mention it, I think mine was uneven when I had it installed too. My passenger side coilover is much further down than the driver's side, lol
Old Apr 19, 2013
GolNat's Avatar
Prelude Owner
I looked at mine too and the passenger side is higher also. Ill have to check again on ground I know is level.
Old Apr 19, 2013
Kenny the Ricer
Not sure...
But the sway bar should be able to move around, if only a little.
But now that you mention that...
I did lower before putting the sway bar on....
Old Apr 20, 2013
j_dock69's Avatar
j_dock69 will become famous soon enough
Maybe your away bar is bent or the bushings shot
Old Apr 21, 2013
drive around a bit, drive like you're testing the suspension.. lol..
Just on the off chance that it "settles out"
Old Apr 21, 2013
krudmuphin's Avatar
maybe it's bent, I dunno
You should take a picture of the sway bar and how the rear sits, that might help us out
Old Apr 21, 2013
TFMEX's Avatar
CO&CA
bushings are brand new (prothane). Sway bar is not bent. One thing I have not done is install it while the suspension was compressed. Im getting an alignment now and will install it within the next week or so... just irritating...
Old Apr 21, 2013
grease well the bushings?
check the mounting points?
put the sway on even ground and check if twisted?
Old Apr 21, 2013
lowlife9's Avatar
doesn't the rsx weigh alot more then the civic couple that with a bent bar and not *torquing down the rears while under load ???
Old Apr 29, 2013
TFMEX's Avatar
CO&CA
It was the sway bar causing my uneven gap... I removed and re-installed the bar after a week of driving with it off. I noticed a HUGE difference without it, and hated it by the way.
Car sit even without it and sits even now with it. I installed it under load which made the difference... who would have thought!
Old Jun 1, 2013
Besimple1's Avatar
Besimple1 is an unknown quantity at this point
I actually might have the same problem. Was your sway bar factory or aftermarket? I just put new springs and shocks on my car and changed one of the bolts and my drivers side sway bar. It sits an inch lower than my passenger side. What exactly did you do to fix yours? I might be trying it. Thanks!
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Firefly
Nov 28, 2001 06:13 PM
CosmicPulse
Nov 9, 2001 05:06 AM
