Going to be imstalling springs today Any pointers?
Hey, so im going to.be installing my tein s techs today, I read over thr DIY about 10 times and I think I got it but is there anything I should look out for? Any problems that I might run into? Im going to spray all the bolts with pb blaster an hour before I start working on it. Anything else I should do? Thanks. This is my first time working on suspension.
Re: Going to be imstalling springs today Any pointers?
I wouldn't recommend that unless you were an actual doctor of sorts.. Patience, however...
But seriously, take your time, double check your work. A torque wrench is your friend.
Separating the tie rod from the strut is prolly gonna frustrate you.. Just a heads up.. Last time I separated my tie rods to adjust my suspension's height, I tore the boots on both of them, and that was while using a tie rod separator, no less..
Sep 26, 2023 06:44 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
EM_WON
Jul 22, 2015 06:49 PM
