Looking for good lowering springs for a 04 Civic
Old Aug 20, 2012
SoysauceSaoy's Avatar
SoysauceSaoy is an unknown quantity at this point
Hey im kinda new to this forum..and before i started working on my civic that was handed down to me when my dad passed away i wanted to make sure i had the details right...im looking for decent lowering springs.. i mean any brand.. but right now i have stock rims/tires on it..
Old Aug 21, 2012
Re: Looking for good lowering springs for a 04 Civic
how low you wanna go? budget?
Old Aug 21, 2012
man i should be better prepared aha...but i dont wanna get craazy low..because i still go to highschol and ****ing speedbumps everywhere but i wanna get low enough to close up the wheel gap alittle bit and budget....mhmm thinking around 200-300? i found some that are 60dollars...but that looks too good to be tru.
Old Aug 21, 2012
krudmuphin's Avatar
Sounds like a reasonable budget for lowering springs. Just go for name brand, avoid the cheap ebay knock-offs. Go for TEIN S-Techs, Eibach Sportlines, Eibach Pro-kit, or Neuspeed springs. You'll want to consider new shocks too, so you don't burst the OEM ones under the pressure of a drop. People here recommend Tokico HP Blues or Koni Yellows. I have coilovers, so I can't vouch either way, but when it comes to springs, I really admire TEIN products.
Old Aug 21, 2012
Me too. I started off with twin s-techs then graduated to Tein SS-P coilovers. $300 is a reasonable budget for springs alone, but you're gonna want to look into struts that can handle the drop, bottom mention camber kit and alignment costs. The springs will prolly run you ~200 or so
Old Aug 22, 2012
aircooledjames's Avatar
aircooledjames is an unknown quantity at this point
If you lower without new shocks, your oem shocks will blow. eibach or tein springs, with koni yellow or bilstein shocks is a good setup. If you are willing to spend a little more get full coilovers.
Old Aug 22, 2012
tokico blues are also a good mate with tein s-techs. Ran that setup for a while, and it was quite nice.
Old Aug 23, 2012
Okay so when i do get lowering sprins ill have to get upgraded shocks and struts?
Old Aug 23, 2012
lowlife9's Avatar
depends on the spring but eventually sooner or later you will need new shocks yes. the stock damper is designed only for the stock spring so you are causing extra wear and tear to the shock. i would get Eibach springs.
Old Aug 24, 2012
Alright thanks everyone for helping me out appreciate it..... now i know what to look for.. thanks!
Old Aug 27, 2012
samgodbout's Avatar
samgodbout is an unknown quantity at this point
It's a good time to buy a good combo shock/spring.
Go to see tokico shock. The tokico D-Spec are at 379 $$ for EP3 on thw web side If i have a good memory. The price is really good.
Old Mar 4, 2013
adrenalinejunky's Avatar
adrenalinejunky is an unknown quantity at this point
so my question is whats the better struts and springs out of all these you guys are talking about in this thread? are the koni yellows better they look alittle more spendy then some of the others and for springs which is the best? im new to this and have been reading as much as i can trying to figure the best setup out on lowering my 04 civic
Old Mar 4, 2013
The tokico blues + tein s-tech setup will lower you just shy of 1.5 inches and give you a slightly stiffer than stock feel. I'd probably still have that setup if I didn't stumble upon the deal for the coilovers I have now.
here's an idea of how it looks on a coupe
Old Mar 4, 2013
krudmuphin's Avatar
Tokico HP "Blues" are easy to install. Koni Yellows require a bit of strut modification, but they allow for a lower drop. (On lowering springs, you should be perfectly fine with Blues)
Brands of lowering spring are almost all the same as long as you buy name-brand. Some people complain that the TEIN and the Eibach sag a lot, but it depends on your set, they all sag eventually.
Google pictures of Civics lowered on TEIN, Eibach, and Neuspeed springs and see which stance you like the best.
I'm partial to TEIN because I own one of their products and I like the cars I've seen with TEIN lowering springs, like riceboy's down there.
Old Mar 5, 2013
Kennykid2002's Avatar
Kenny the Ricer
I wish my teins would sag....
Not low enough.
I shouldn't say that, watch my struts blow *knock on wood*
Old Mar 5, 2013
enigmatic jc's Avatar
enigmatic jc is an unknown quantity at this point
im lowered on eibach sportlines on tokico hp struts on a sedan
Old Mar 5, 2013
Nice clean looking cars I like the looks...how is the ride with these setups? Are coilovers any better riding or they a lot stiffer?..im looking to drop alitte but still have a good ride?
Old Mar 5, 2013
S-techs with tokicos was really comfortable. Just a hair stiffer than stock. With coilovers, it depends. My current setup, I can adjust the dampering, so I can either feel the slightest crack in the road or I can make it softer than... Some.. Soft.. Stuff... Lol
Old Mar 5, 2013
What coil overs do you have and how spendy are they?
Old Mar 5, 2013
I'm rockin Tein SS's with pillowball upper mounts.
http://thmotorsports.com/tein/tein_d...1/i-36019.aspx
Coupon code "5offfive" brings it down to $1218 shipped. Better deal than I got back in '05
Old Mar 5, 2013
Is this the way to go if a guy can afford it then? And thx for all the useful info
Old Mar 5, 2013
if you can afford it, then by all means, go for it.
Old Mar 5, 2013
krudmuphin's Avatar
Errr... maybe.
Those are some fancy pants coilovers riceboy has...
You only need entry level ones for street use. Without adjustable damping, you'll be around $850, with damping is closer to $1000. Kits like the Skunk2 Pro-S II, Megan Racing Coilovers, and TEIN Street Basis are cheapest and get the job done pretty well.
Coilovers definitely have their advantages of spring/strut combos, but it depends on how much you want to spend. There's nothing wrong with a good spring setup vs. low end coilovers.
Comfort wise: springs are usually more comfy. My Coilovers are pretty stiff.
Old Mar 8, 2013
Is 500 about the going rate for a set of the tokico blues?
Old Mar 8, 2013
Kenny the Ricer
That's why you pay extra for the dampening
Pretty much.
New goes for about $500~650 I believe
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
dooner24
Apr 14, 2015 07:51 PM
Zillaaa
Nov 2, 2001 05:11 PM
ImmortalEX
Oct 31, 2001 10:00 PM
