Uneven drop?
Old Apr 28, 2012
vi3tx13oy's Avatar
vi3tx13oy is an unknown quantity at this point
Uneven drop?
Hi i just recently got tein s tech springs with tokico hp struts. I got them installed at the shop and then i got my alignment a week later. Oh i also installed my spc cambers kit ( front and rear). Anyways the main point here is that the front suspension seems to be uneven. On the rear i have a very tight 2 finger gap maybe even a one and a half finger gap on both sides. While one the front left its a 2 finger gap and on the front right it a 3 finger gap. U wouldnt notice any difference from far or even from close but i just dont like the fact that its not even everywhere. I get the that front andd rear dont have to be at the same height but im just a bit annoyed that both fronts arnt dropped evenly. Should i take it back? Or should i leave it as it is? Its been 3 weeks that its been dropped. Oh and lets say i do bring it back and its ajusted do i have to do an alignment again?
Old Apr 28, 2012
sl33pyriceboi's Avatar
Re: Uneven drop?
^thats normal.
the front has a bigger gap than the rear (even in stock form), it compensates for the turning of the tires. so if ur springs drop 1.5" all around you will still retain a bigger gap in front than in rear.
one of the reasons why you get coilovers.
Old Apr 29, 2012
vi3tx13oy's Avatar
Re: Uneven drop?
Yeah i understand but both my fronts arent even, is that normal? My right side is a finger gap higher than the left side
Old Apr 29, 2012
Re: Uneven drop?
^yea, thats not normal. who installed ur spring? the spring is probably seated incorrectly.
also, where did u get ur Stech? there are a WHOLE BUNCA fake Stechs out there.
http://www.tein.com/counterfeit/index.html
Old Apr 30, 2012
vi3tx13oy's Avatar
Re: Uneven drop?
Ohh okay then, ill probably go get it readjusted. Would that mean i would have to do another alignment?
Old Apr 30, 2012
Re: Uneven drop?
the weight distribution left/right being different can cause that. plus having only a driver and no passenger.
Old Apr 30, 2012
MindBomber's Avatar
Live for the Twisties
Re: Uneven drop?
Most likely the spring on the high side is not seated correctly, as was stated by James, the lack of a passenger on one side has never caused any car I've ever seen to sag.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Juanb24
Sep 15, 2015 12:39 AM
