Coilover Vs Shocks and Springs HELP
Old Jul 23, 2011
Wilsky's Avatar
Wilsky will become famous soon enoughWilsky will become famous soon enough
I am torn between these two forms of lowering my car. I have the sedan, and have heard that most of the springs are made for the coupe, so I will sag in the back. If I buy coilovers I know that I can prevent this, but they are also $400 more. Should I go with the springs and risk my car unevenly lowering or just use the money and go with the coilovers. And by the way if I went the spring route, I would get tokico blues with eibach sportlines, if I bought coilovers I would go either progress or d2.
Also where is a good place to buy these products? Thanks a lot.
Old Jul 23, 2011
maxtierney's Avatar
EM2ti
Re: Coilover Vs Shocks and Springs HELP
Believe it or not, most of the sag is from bad shocks, not the springs themselves.
Comfort-wise, progressive springs provide the best ride - hands down.
Bling Factor (for most people) and adjustablity - Coilovers.
Best of both worlds - Ground Control Sleeves. You pick the shock, spring rates, topmounts, etc.
Old Jul 23, 2011
sl33pyriceboi's Avatar
If u get springs and do it right, you will sPend almost as much as a coilover system because spring + strut is just about the same price as coilovers
So do yourself a favor and get coilovers
Old Jul 23, 2011
tencc's Avatar
tencc will become famous soon enough
Full coilover set up is the best way to go and its very easy to do. Some set ups have pillow ball mount tops on the front coilovers to adjust camber, but you have to buy a seperate camber kit for the rear. Camber kits are recommended to prevent uneven tire wear. After you adjust the height, adjust camber as close as you can then bring the car to an alignment shop, then your set. Just do your research on the differrent brands and what models and features to choose from.
Old Jul 23, 2011
MindBomber's Avatar
Live for the Twisties
Ground controls would be my vote if your not building a heavily modified suspension.
Old Jul 23, 2011
lowlife9's Avatar
did somebody say progress technology. this is where i ordered mine the were 900 a month ago i guess they went up in price ??
http://www.corsportusa.com/store/cat...roducts_id=481
found them cheaper here
http://thmotorsports.com/progress_te...6/i-39833.aspx
Old Jul 24, 2011
Wilsky's Avatar
Alright well what is better progress or d2 and which costs the most? Im in Canada too are there any canadian sites that have these sort of parts?
Old Jul 24, 2011
lowlife9's Avatar
progress is by far better then D2.
Tedverseti
Apr 23, 2020 01:45 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Tedverseti
Sep 29, 2015 05:41 PM
Bruce2
Sep 27, 2015 08:45 PM
