I need tie rod ends... Go stock or aftermarket?
Old Jun 16, 2011
CGaud's Avatar
CGaud is an unknown quantity at this point
I bought some rsx coilovers and need to upgrade my tie rod ends to make them fit... I know this but should I go aftermarket (inverted tie rod ends) or use OEM tie rods? I can get some OEM's used with low miles for $45 shipped. What ya think?
Old Jun 16, 2011
MindBomber's Avatar
Live for the Twisties
Re: I need tie rod ends... Go stock or aftermarket?
Go for the j's racing ones lol
Old Jun 16, 2011
BlueEM2's Avatar
Whachya lookin at?
http://www.dezod.com/cat_tie_rods.cfm
Old Jun 16, 2011
CGaud's Avatar
Originally Posted by tbohar
These ones are for 01-05 civic...from what I have read I'll need the Rsx tie rod ends (larger) to fit my new coilovers (marketed for the Rsx). My current Civic tie rod ends have no issues besides the size.
Old Jun 16, 2011
BlueEM2's Avatar
Whachya lookin at?
OEM should be good enough but you could upgrade... it's up to you and how much your willing to spend.. how much are the J racing ones Austin?
Old Jun 16, 2011
CGaud's Avatar
Thanks for your help. Just picked up those used OEM ones. Spent $700 on coils and camber already...so tempted to do five lug conversion while I'm at it!
Old Jun 16, 2011
MindBomber's Avatar
If memory serves the j's racing are $200 a peice, so a full set is $800 lol
Old Jun 16, 2011
maxtierney's Avatar
EM2ti
I've got the J's racing Tie Rod Ends for the EP3. They run about $275 to $300, I can't remember. They come as a set with the tie rods.
How low are you going? The inverted ones are nice (I've also got a set of Inverted T1Rs). The problem is that stock tie rods with the inverted Tie Rods will only give you so much toe in or out, depending on your drop, camber and coilover tie rod connection height. Some guys need a longer bar with more thread, some need less bar with the same amount of thread, etc. Don't count on having one set-up in mind until your suspension is on the car and you are doing the alignment. I had the J's on and the T1Rs
with me when I got my alignment. Tried both out. The inverted helped greatly with the tie rod angle but didn't give me enough toe out with the amount of camber I needed. I'm getting a custom set of tie rods made specifically for my set up.
Good luck.
Old Jun 16, 2011
lazlong's Avatar
I know you already got OEM but, I'm happy with my MOOG brand- and they were only $45 apiece.
Old Jun 17, 2011
lowlife9's Avatar
i believe the j's are shorter then the stock thats why the toe issues . you can actually invert your stock ones if you don't mind step drilling your coilovers.
Old Jun 17, 2011
CGaud's Avatar
I'm not really trying to go too low with my DD, maybe just two fingers all around. I also looked into the Moogs and liked the fact they could be easily regreased... if I ever need to change or upgrade I may just get them and invert them if necessary. Then again, I'm not even sure I'm going low enough to need them inverted. I'll just have to see how it goes on install day.
I should be getting everything by the end of next week. Man, I love getting packages in the mail!
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
hans.pcguy
Jul 12, 2015 12:19 PM
sdraza1
Jul 2, 2015 06:04 PM
tomg
May 21, 2015 07:05 AM
El_Spic
Apr 23, 2015 03:14 PM
