Vibration/Steering Issues hard to diagnose
Old May 10, 2011
DahrkDaiz's Avatar
DahrkDaiz is an unknown quantity at this point
So I took my car to my personal mechanic and explained the following issues: For about 2 years now I've noticed a slight vibration that has progressively gotten worse in the steering wheel. I figured it might be an alignment/balance issue. When I got my tires replaced, they were aligned and balanced, however, now the car has a pretty consistent vibration described as such:
At highway speeds (50-65mph) there is a slight to strong vibration in the steering wheel jarring back and forth. However, sometimes the vibration will transfer to the seat. I can literally feel the vibration in the steering wheel start to lessen but strengthen in the seat and it will oscillate (sometimes) like this. Sometimes it won't vibrate at all.
Sometimes, when braking sudden or from a higher speed, there's a pulsating pull/push feeling that seems to come from one side of the car.
Finally, at some speeds when turning, when I let go of the steering wheel it will feel like it's catching before it returns to the center position. After the alignment, the steering wheel was straight but it seems after 2 or 3 weeks it's starting to **** to the right again.
Edit: One other thing, before the tires were replaced, some of the tires were feathered and one tire was severely worn more than the other 3.
All the of these symptoms don't always happen, but when they do they're always the same. My mechanic is having a hard time locating the issue. My first suspect was control arm or control arm bushings but I think he probably ruled those out. Any suggestions?
Old May 10, 2011
MelJ's Avatar
Trance Addict
Re: Vibration/Steering Issues hard to diagnose
Add checking outer tie rod ends to the list. Check the boots for tears and check for play. There should be none. The pulsation from stopping and pulling to one side could be a brake issue.
Old May 10, 2011
DahrkDaiz's Avatar
Yeah my next guess was going to be tie rod ends since I do hear a clunk from the passenger side over bumps, but I just assumed this was the strut going bad. I am a bit concerned that my mechanic was saying they think it's somewhere in the driveline and was asking me if I ever had tranny issues, but I guess driveline includes anything that makes allows the car to continue moving forward after the engine/transmission gives it power?
Old May 10, 2011
What_It_Do's Avatar
What_It_Do will become famous soon enough
When you experience the vibration while driving, put your car in neutral. If the vibration is still present. Than it's probably not driveline.
Old May 10, 2011
DahrkDaiz's Avatar
Edit: no post. Sorry.
Old May 10, 2011
arubio0812's Avatar
arubio0812 is an unknown quantity at this point
im a rookie but i have owned nothing but hondas for the 5 years ive been driving, check the rotors, if there old they can warp and cause bad vibration, also check if the rotor screws are tightened enough sometime loose rotors will cause this too.
Old May 10, 2011
MelJ's Avatar
Trance Addict
That pertains to any car, not just Hondas .
Old May 10, 2011
arubio0812's Avatar
btw i have steering vibration in my steering wheel too in my 2002 civic 4 dr, i just got my wheels balanced, checked the sway bar links (there good), butt, im missing one screw on one rotor, driver strut is oozing, and the passenger side bushing (the big one towards the front is cracked. Which one of these could cause the vibration when i turn my wheel and whenever im driving fast or acclerating
Old May 10, 2011
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
If your talking about the two screws in the center of the rotor those are not needed at all the lug nuts will hold your rotors on just fine. I would start by looking at your axles put the car in the air (safely) and start accelerating inspect your axle's for wobble.
Old May 10, 2011
BlueEM2's Avatar
Whachya lookin at?
It could also be a warped rim.
Old May 11, 2011
DahrkDaiz's Avatar
Well I got the car back and my mechanic says he thinks it's in the transmission or the axle and that it's coming from the driver's side. I'm not entirely sure why transmission issues would cause a steering wheel wobble and no actual gear shifting issues. If it were really axle based, then would the speed really matter? The wobble _only_ happens at speeds above 50 mph and sometimes when steering at certain angles.
And, one last thing, I don't know if this is related, but in the winter during really cold days it feels as if the is a wobble on the passenger side of the car that goes away once the car warms up. No clue if it's related, but wouldn't be surprised.
Burnout
Jul 15, 2022 10:24 PM
juror
Jun 9, 2015 02:15 PM
Black91civic
Jun 6, 2015 08:15 AM
pantdino
15
May 13, 2015 02:22 PM
bluecoupe
Jan 30, 2002 08:43 PM
