Suspension Replacement
Old Mar 31, 2011
Staninator's Avatar
Staninator is an unknown quantity at this point
So I'm guessing I'm due for a suspension replacement soon here. I have an 01' EX with 123k miles on it. Would it be wise to stick with factory components for a replacement or going aftermarket for longevity? I would be replacing the shocks and springs. Also, is there anything else that I would need to replace since I'm already down there?
Old Mar 31, 2011
MindBomber's Avatar
Live for the Twisties
Re: Suspension Replacement
Whether you have anything else you need to replace is difficult to say, you may need to replace your:
Ball joints,
Tie rod ends,
LCA bushings,
Strut mounts.
Kyb Gr-2 struts are an OEM replacement and have the comfortable ride your accustomed to, but if you want something that will last years and don't mind a stiff ride then look into tokico hp shocks and struts. The OEM springs have a tendency to sag, but should last you many years regardless; again, if you don't mind a stiff ride you could go with tein h.tech or eibach sportlines that will last longer but have a somewhat stiff ride.
Old Mar 31, 2011
link7's Avatar
link7 is an unknown quantity at this point
Inspect it before replacing everything. My '05 EX has 132 and i just replaced ball joints LCA bushing and rear shocks. Everything else was fine and that was the first time I had any suspension work done.
The rest may go shortly after but who knows. My approach is, if it ain't broke don't fix it.
I think springs are a lifetime part unless they are damaged for some reason.
Old Mar 31, 2011
MindBomber's Avatar
They don't wear out like struts or ball joints, but overtime their ability to hold up the car diminishes and the cars ride will suffer.
Old Apr 2, 2011
Staninator's Avatar
I thought the Tokico shocks aren't that great because they leak after a while. Would it be worth it to get a tein coilover set or anything like that instead of getting factory replacements?
Old Apr 2, 2011
MindBomber's Avatar
Tokico struts have a lifetime warranty if they're installed correctly and not used with lowering springs lower than 1.8 inches.
Buddy Club, Tein, Progress or a G/C koni combo are all worthwhile if you can afford them and are willing to sacrifice comfort for performance.
Old Apr 3, 2011
Staninator's Avatar
Alright man thanks for the info! I have looked into coilover sets so we'll see what I want to do.
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
