Strut mounts and Bearings help
I have 2001 civic EX coupe I changed the front shocked without changing anything else. The shocked I got were something aftermarket(Advanced auto international brand)
I'm planning to get
1-51402-S5A-024 RUBBER, FR. SPRING MOUNTING
2-51688-S5A-014 SEAT, SPRING (UPPER)
3-51726-S5A-004 BEARING, FR. SHOCK ABSORBER MOUNT
4-51920-S5A-024 MOUNT, R. FR. SHOCK ABSORBER (Left and Right)
My car ride very stiff and I can hear everything inside even with a very small bump! with a clunking noise from the front strut mount, Also alignment problems,
Do I need to get all of these or some ? Which part that doesn't need to be replaced ? Or reused
Any body changed those and felt any difference ?
Please help
I have searched the forum for posts but nothing really answers these question
I'm planning to get
Please help
Re: Strut mounts and Bearings help
I just replaced my front stock struts with the KYB GR2's. I had a clunking noise from the passenger side strut, upper mount (after the install). The mount went bad. I think the bearing was damaged as well, it appeared to be sunk in too far into the mount when i took it out and inspected it. I could see where the clunking noise was coming from when i had the strut out of the car. It was basically the whole strut, the upper mount specifically, knocking against the frame of my car, the inside of the strut tower, to be more specific... again..
I threw a new upper mount in and it seemed to take care of my problems. I also had some binding/popping noise with that strut. I had my mechanic lube up the top of the upper mount as a precaution, though i'm sure this wasn't necessary. I think the binding was the bad bearing. So, if i were you i would start with the mount, which includes the bearing. Take a look at the rubber strut boot to see if it looks worn and use your better judgment to decide if replacing it is worth the money. I'm not a mechanic, so don't press charges if my information doesn't apply to, or doesn't help you.
Although it is necessary to need an alignment after installing, or even touching just about anything related to the suspension, I would say you should fix your problems before having the alignment checked. My alignment is off a few inches since the new front struts (about a week ago). But i wanna make sure nothing else goes wrong before i have it done, so ill give it a month. I cal live with the alignment, so long as the struts are performing properly.
not really sure if the spring seats would help on your problem, but since you will need to take the shocks out, you could do that for peace of mind.
the stiff thing could just be the new shcoks.
clunking could be the mounts or sway bar endlinks among other stuff
Thanks guys. (I have a clunking noise from the passenger side strut) Same here.
Here is the thing ! I'm planning to get the strut mounts from Honda however I found somewhere that the Mounts for 2001 and 2002 Civics are Plastic ? And the ones for the 03-05 and metal ! Is this true ? The ones for 03 are little bit more expansive than the 01 . The KYB Mounts comes with bearings with them and its tempting lol.
The sway bar links looks good.
I had done alignment like 4 times and each time it pulls to a different side ! Pboys sucks but maybe its not there fault. I know now that I have bad Tie Rod (Left)
And planning on getting it from Honda as well
I would greatly appreciate your inputs here
Thanks
Thanks
I guess there is no more information can be added to my question
Now that I need to know if the mounts from the civics 02-05 will fit on my 01 civic EX ? I went to the dealer and they dont know !
Did somebody tried to install these on 01 civic ?
The part numbers for the 02 are
51726-S5A-701 009 002 BEARING, FR. SHOCK ABSORBER MOUNT
51920-S5A-751 010 001 MOUNT, R. FR. SHOCK ABSORBER
The ones for 01
51920-S5A-024 010 001 MOUNT, R. FR. SHOCK ABSORBER
51925-S5A-024 011 001 MOUNT, L. FR. SHOCK ABSORBER
The 01 mounts will fit the SIs as well !
The ones for 01
Sep 26, 2023 06:44 PM
honda.lioness
16
Feb 10, 2017 10:53 PM
Amulon
Aug 18, 2015 11:03 AM
alaga
25
Aug 13, 2015 04:42 PM
