Rear Sway Bar Links broken....
Old Oct 26, 2010
Staninator's Avatar
Staninator is an unknown quantity at this point
Hey guys I was wondering if there are any aftermarket rear sway bar links that I could get to replace the factory ones in my '01 ex? I can get the genuine honda ones but I wouldn't mind getting something that may last a bit longer... Any recommendations? Anything at Oreilly or Autozone that would be worth my money?
Old Oct 26, 2010
02civicsi02's Avatar
Low and slow!
Re: Rear Sway Bar Links broken....
The oem endlinks at honda are perfect and are good endlinks. They are actually better than the aftermarket ones.
Old Oct 26, 2010
Staninator's Avatar
Okay thanks man! I'll just stick with genuine parts.
Old Oct 26, 2010
I think gearbox does recommend the moog ones with grease tips.
Old Oct 26, 2010
lazlong's Avatar
X2. You will notice how much more robust they are when you see 'em. They're about $50 each at O'reillys.
Old Oct 26, 2010
Staninator's Avatar
I read about those Moog ones but I heard that they were kind of noisy. What kind of noise to they emit?
Old Oct 26, 2010
I think we need to wait for gearbox to butt in, or you could do a search on them
Old Oct 27, 2010
the moog is as quiet as stock. these are not bushings, they are just endlinks and they come pregreased with a boot over everything. so no chance of any noise. moog is also double the thickness of stock and has grease ports to add more later if needed. stock is too weak. i have moog links front and back with zero noises. my only noise during the winter comes from the front ES LCA bushings squeaking. now you do get lots of noise from those aftermarket metal endlinks like the ones in the other thread.
Old Oct 27, 2010
Staninator's Avatar
Alright man thanks for the info! I'll be picking up a pair as soon as I make some money
Old Oct 27, 2010
lazlong's Avatar
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
fordover
Jul 11, 2015 09:10 PM
OptimisticWay
Jul 10, 2015 04:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
