lowering spring
Old Aug 10, 2010
smiley813's Avatar
smiley813 is an unknown quantity at this point
lowering spring
I have a honda civic 01 I had coil lower on but I took them off and put lowering springs. Put now every time I turn my spring also seem to turn a all you hear is a craking noise.what can I do bout that.
Old Aug 12, 2010
02civicsi02's Avatar
Low and slow!
Re: lowering spring
The springs are not sitting right in the strut, I had this happen to me one time. Just take the strut off and realign the spring right and it should be fine.
Old Aug 12, 2010
Re: lowering spring
Originally Posted by Burt Grady
Most custom wheel shops offer lowering packages with purchase of wheels,or they may refer you to a shop they trust,be sure you purchase quality parts that will not only lower your vehicle but give you a smooth ride whatever you do don't get your springs heated or cut,you will get the worst ride you could imagine,be sure you also have an alignment performed on your vehicle also check with your state law on how low you can go or you may get ticketed.
go away from here, spammer.
Old Aug 12, 2010
Re: lowering spring
i believe if they were stock springs they should have some markings in the spring as well as in the strut seatings, but not sure if your aftermarket springs will have them to align with the strut.
But yeah, the springs need to be aligned.
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
