2001 front tie rod end replacement?
Old Sep 27, 2009
Sanchothepanda's Avatar
Sanchothepanda is an unknown quantity at this point
Managed to rip the grease boot on one while replacing my old struts with some new KYB's . Are they just threaded on or is there some special tool/process I'm going to need to get it off? Also, what is the castley-looking nut on the bolt shown here http://www.car-stuff.com/includes/se...QgdGhlIHBhcnQu because that's definitely not on my car. Mine has a nut that you thread up and a cotter pin that fits through the bolt below it...
Old Sep 27, 2009
Donkeyweezil's Avatar
Donkeyweezil is an unknown quantity at this point
Re: 2001 front tie rod end replacement?
Take the nut off and then pound a pickle fork in between the ball joint and the hub. this will seperate the two pieces.. then twist off the balljoint from the steering arm. replace the ball joint and torque the castle nut to about 60 pounds... install the cotter pin when the castle nut is lined up with the hole in the balljoint threads...
CarStuff
Dec 6, 2020 12:52 PM
bsmiley
Apr 27, 2015 01:27 PM
El_Spic
Apr 23, 2015 03:14 PM
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
