Lower control arm bushings installed the wrong way please help
Old Aug 12, 2009
kakarotus's Avatar
kakarotus is an unknown quantity at this point
Question Lower control arm bushings installed the wrong way please help
Just taked my 03 EX Coupe to get the front lower arms bushings replaced. The car started to feel weird so I asked a buddy who also has the same car, and told me that the bushings may have been installed the wrong way.
Is there a way they should be installed, and if so what is the correct position? A picture or directions would be really apreciated.
Thanks in advance for your help.
This is my first post so bear with me please.
Old Aug 13, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: Lower control arm bushings installed the wrong way
If you look at the actual bushing thats installed on the car (Turn your wheels all the way in one direction and you will be able to see the bushing on one side or the other). When looking at it you should be able to see a little line on it that sticks up higher than any other part of the bushing. If you can't see the line the bushing was installed the wrong way. I'd go outside and take a picture for you but its awful dark outside. The line should be pointing away from the engine and a little bit towards the back of the car. (If mine were installed correctly lol)
Old Aug 13, 2009
kakarotus's Avatar
The bushing has two arrows in one side, the arrows showld be up o down and pointing in which direction?
Old Aug 13, 2009
kcari's Avatar
maybe you just need an alignment??
Old Aug 13, 2009
kakarotus's Avatar
Re: Lower control arm bushings installed the wrong way please help
One bushing was installed upside down, is there a problem because of this? Showld I take it down to be turned over or just leave it
Old Aug 13, 2009
i really dont think its possible to install them the wrong way. they look the same when installed either way. you did get an alignment like youre supposed to after any suspension work right?
Old Aug 13, 2009
kakarotus's Avatar
Yes, the car got aligned properly maybe it feels stiffer but that's normal after the bushings replacement. My concern is about the way they were installed
Old Aug 13, 2009
kcari's Avatar
how does the car drive differently? does it sway right or left even though ur holding the steering wheel tightly? Does it shake or what?
Old Aug 14, 2009
Zzyzx's Avatar
Autocross Junky
Um, they are bushings. there is no "wrong way" to install them on the front LCA.
Now if they were offset bushings designed to increase caster then they could be installed wrong.
What bushings are you using?
GolNat
Sep 10, 2015 08:25 PM
beachglass
May 22, 2015 09:59 PM
bryden13
May 18, 2015 12:22 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
