drop problem!!!!!!!!!!!!
Old Feb 19, 2009
lowlife9's Avatar
Exclamation drop problem!!!!!!!!!!!!
i want to drop but my exhaust is to low what are my options i just got this exhaust at the end of summer so its basically new its 2?1/2 inch tusudo n1??????
Old Feb 19, 2009
elementalchain's Avatar
elementalchain is an unknown quantity at this point
Re: drop problem!!!!!!!!!!!!
i would say to maybe grind down the bottom of the flange where the exhaust bolts together. I have a tsudo exhaust as well but i am only dropped 1.75f and 1.5 r on 215 45 17. I have rubbed going over speed bumps a few times.
Old Feb 19, 2009
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
Hah, welcome to driving a lowered car. EM/ES's have a pretty shallow exhaust tunnel too, so they tend to hang low with aftermarket stuff. (My Integra is almost a full inch lower than my Civic was, and I almost never hit the exhaust). It will scrap on speed bumps and when you go up a ramp like at the end of a driveway with a sidewalk, but it shouldn't be any really bad damage. You could have a shop just weld the pipes together and ditch the flange, or grind away like elemental said. Or just see how bad it is, and go from there. A little bit of scraping won't hurt it too much as long as you take it real slow as you scrape.
Old Feb 19, 2009
lowlife9's Avatar
well i was planing 2.5 or 3 inch drop on a 15by 8 xxr 501 with a 195/50/15 stretched tire
Old Feb 19, 2009
kcari's Avatar
get a bigger rim and a bigger tire or don't drop that low.
Old Feb 19, 2009
bakertime's Avatar
The lower you go, the more compromises you have to make. Whether that means scraping, or a lot of negative camber to clear your fenders...it probably isn't going to be like stock, hah. Since you're getting coilovers, I would start higher than that and see how it goes. After a while if you want it lower, then go for it. Just make sure you get an alignment both times or you'll shred your tires in no time.
Old Feb 19, 2009
lowlife9's Avatar
im thinking of cutting the lower part and welding on a smaller tube and angle it a little higher to be almost flush with the heat sheald im not worried about performance loss i mean **** its a vp non vtec i basically got the exhaust to make it sound nice.how much do you think that would cost at a shop it cant be that much??????.......ya and my style isant exactly normal i want lots of wheel poke im going towards more of a hybrid tuner/lowrider look .
Old Feb 19, 2009
kcari's Avatar
closer to the heat shield might mean more banging and noise, especially in the rain.
Old Feb 20, 2009
sl33pyriceboi's Avatar
get a muffler shop to weld rasier supports for it.
i have a magnaflow full catback (3" piping i believe)
and i am slammed.
Old Feb 20, 2009
kcari's Avatar
not as low as he's wanting to go...!!
Old Feb 21, 2009
^oh trust me, i am alot lower, you use to be able to see my exhaust mid pipe hanging from a distance. it had a 1" clearance from the ground
Old Feb 21, 2009
kcari's Avatar
ricer
Old Feb 22, 2009
^x2
Old Feb 22, 2009
D5cIvIc's Avatar
and i am slammed.
post pics...we'll judge if you're slammed or if it's ur kit.
POST PICS NOW!!
mikemc422
Aug 9, 2018 05:41 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
aZnVoYCe
Nov 11, 2001 10:43 PM
