Alignment ?
Old Nov 27, 2008
02civicg5's Avatar
02civicg5 will become famous soon enough
Alignment ?
hey i wanted to ask a quik ? im dropped on tokiko blues and eibach sportlines.. i was wondering if i can get close to zero toe witout getting much spec on camber?? i dont have a camber kit installed and wanted to noe if i take it for an alignment can they align my camber and toe close to spec witout a problem??
Old Nov 28, 2008
Re: Alignment ?
dont even bother taking it in without a camber kit. they will send you away. i was dropped on prokit and they couldnt adjust the rear at all without one.
Old Nov 28, 2008
02civicg5's Avatar
Re: Alignment ?
can they still adjust my toe though???
Old Nov 28, 2008
kcari's Avatar
Re: Alignment ?
yes.
Old Nov 28, 2008
Re: Alignment ?
yeah but what does that accomplish lol
Old Nov 28, 2008
02civicg5's Avatar
Re: Alignment ?
alot actually like my car wont go from side to side in the highway and toe kills tires more then camber
Old Nov 29, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Alignment ?
It keeps your tires from shredding. You don't really need a camber kit with the prokit unless you want to get within certain specs. If you are willing to tolerate the camber your car gets while lowering with the prokit, then just get the toe to zero. And yes you can get 0 toe with the prokit.
Old Nov 29, 2008
Re: Alignment ?
yeah but i dont like having the rear tires be at an angle
Old Nov 29, 2008
kcari's Avatar
Re: Alignment ?
dont u pretty much want all 4 tires to be at around -1 degrees anyways?
Old Nov 29, 2008
02civicg5's Avatar
Re: Alignment ?
lol u right.. i dont mine the camber... its not that bad and plus i get betta handling..
Old Dec 18, 2008
keepItJDM's Avatar
keepItJDM is an unknown quantity at this point
Re: Alignment ?
as soon as you're 1.5" lower a camber kit is needed
Old Dec 19, 2008
robbclark1's Avatar
Re: Alignment ?
shut up.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
TheRiddicles
Sep 21, 2015 01:28 AM
