Alignment specs.
Alignment specs.
Went for an alignment a week ago. Checked the specs given to me. I had a 0 degree camber setting on the rear driver side and a -1.4 degree camber setting in the rear passenger side (was not adjusted during alignment). Gap in the rear is at around a snug 1-finger gap.
There's no rub on the driver's side, which leads me to believe that I can get a closer camber rating on my rear passenger side. The camber difference between both tires are definitely noticeable. But when I went to talk to the mechanic (for the Canadians here, I went to Canadian "Crappy" Tire -_-) he says the toe is my greater concern for tire wear. He didn't adjust camber because Honda does not have an OEM spec for rear camber.
Bullshit, I thought.
I understand the toe being the primary reason for tire wear, but little/no concern for camber? What the hell? I kept telling the guy that I had a camber kit installed in the rear and he's telling me this bullshit about how it'll cost extra to adjust it.
Sorry, digressing.
Anyway, my main question is, would I be able to adjust my camber in the rear passenger side WITHOUT disrupting the toe and the thrust angle? To my understanding, toe has the affect of the thrust angle and camber affects cornering grip ability. I will be going back for another alignment in a couple months after the springs settle.
Sorry, digressing.
Re: Alignment specs.
i'd suggest you get some more negative camber in your passanger rear. once you load your car in a turn or with people even, and your springs compress, you'll have a good chance of the tire rubbing against the car. trust me, thats the last thing you'll want.
to answer your question, i do believe you can adjust the rear camber without changing the toe, however, without proper equipment, its likely you'll throw something off.
Well, I've loaded passengers in my car with this camber setting and I've experienced no rub on the rear driver side, which is why I wonder whether a self adjustment to a similar camber setting on the passenger rear would cause my car to lose its near-perfect thrust angle.
I have an SPC camber kit installed in the rear, so it makes camber adjustment easier. The re-alignment will come in a couple of months, since my alignment is warranted for 100 days.
Does anyone know if there is an OEM camber setting in the rear?
From what I hear, crappy tire here has a certain amount of days that you can bring it back to check on the alignment status if you decide to change your spec. Not sure about the locations in the GTA.
i believe it was 65 for everything
45 for teh front and 20 for the rear...and they will put it to what ever spec/degree you want it.
i got -1.5 all round with brand new tires. my tires are turning into slicks now and the wear is completely even.
TheRiddicles
Sep 21, 2015 01:28 AM
