HELP skunk2 coilover / tokico d spec shock
hello,
I just got some skunk2 coilovers/tokico d spec shocks. has anyone ever installed this before? The reason i ask, is because the springs are alot smaller then the stock springs, and i'm not sure how they will fit the shocks. Can anyone please help?
Thank you,
Joe
Thank you,
Joe
Re: HELP skunk2 coilover / tokico d spec shock
did you actually even attempt to put it all together before asking? It sounds like you are assuming in my opinion. By the way, any "true" coilover springs that I have seen look smaller than stock...sounds like you have sleeves...so they should have came with the sleeves...and the springs should sit on those.
Nooblet, it is because they are linear springs. Stock springs are progressive springs. Just put them together first, then ask questions.
Bruce2
Sep 27, 2015 08:45 PM
