do i need a drop
do i need a drop
If i put the 15' axis oldschool rim on with the stock suspension do u think it would look funny....how big of a gap will i get.
WHat should i get to lower the car to make the rims sit well with the car.
"mmmBAHHHH" - vtec y0
Re: do i need a drop
with 15's with a stock tire size itll look stock. of course lowering the car will make it look better. but your question has such a broad range of awnsers
Specifying the wheel size is pointless, all wheel/tire combinations should have the same rolling diameter as a stock setup. For example, my stock 14s had a 70 series tire so when I moved to a 18 inch wheel, I have a 35 series tire so my odometer and speedometer are still very close to normal. So basically the more rubber you have, the more wheel well you cover. The less rubber, the more visible wheel well. But you also have to consider the rolling diameter since, "I'm sorry, my speedometer is off because I'm a moron who can't buy tires" isn't accepted by state patrol.
gear just curious as to what you have? i know your droppdd. I actually saw one civic in my area that had 15's and was nice. it had tints, and factory lip kits. much like my car. it wasnt droppedd, but looked nice and a little more uplevel than a civic
i find 15's a little too small for our 7th gens... i believe 16's is the perfect size, covers up the wheel gaps a little more without having to slam our rides... rather than having 15's and making it difficult to get around certain dips and speed bumps
so what do you guys think...you think the 15'a are gonna be to small or should i go with a 16'
if i do go with the 15' axis oldschool rims do i need a camber kit or no. and im gonna run them with this tire size...205/60/R15 FALKEN ZE-912
plz help guys wanna buy these tonight
I think that even 17's need a drop otherwise just looks like a cheap cop out. But keep in mind not to do the other cheap cop out with springs that give your car a super bouncy look/ride when driving on the highway. If you don't have the funds to do it right away wait till you can and ride stock for a while longer. Just my opinion though so do what ever you want.
im def gonna get the 15 axis but how low do you think i would need to go. VARNER told me like 2.25'' do you think that is to far of a drop for everyday driving.
ALso what should i get to make this drop look good and last a while...help plz
i have a 1.5" drop and it is good for me for daily driving. looks great too. Just get some coil-over sleeves and then you can decide the drop and if you want to change it you can at any time. most go from stock height to about a 2.5" drop and any where in between.
well im gonna sit on a 195/50/15 tire cause thats what the guy i talked to said would fit on my car...i asked him about the gap and he said it should look decent so maybe all that i will need is a 1'' drop...
Heres my ride on 195/50/15 With S techs + Blues. Gap could be better... but dips+bumps+driveways are sometime a pain to go pass because i scrape alot... here are pix
http://img.photobucket.com/albums/v4...l/DSC05408.jpg
http://img.photobucket.com/albums/v4...l/DSC05411.jpg
http://img.photobucket.com/albums/v4...l/DSC05402.jpg
goodluck
goodluck
TheRiddicles
Sep 21, 2015 01:28 AM
Juanb24
Sep 15, 2015 12:39 AM
