Tein Springs worth the worry in this case?
Old Feb 7, 2008
TakumiFujiwara's Avatar
TakumiFujiwara is an unknown quantity at this point
Hey guys,
I was told by a couple of people I know that by the way I drive my car, I should think about getting myself a set of springs not only to lower the car a bit but also to have better springs since they are telling me that the stock springs aren't too great. So until I can fork out the money for coilovers, I guess I should be buying some springs. I was looking at a set of Tein springs that will give me a 1.5 inch drop approximately and I am just wondering if there is a point to it. I haven't been able to find any information on what this will do to my ride. Some people are telling me that it will help me since lowering it a bit will help me and also just having stronger springs would be a good idea. However one person I know in particular is telling me that it's a really bad idea because just a set of springs instead of full coilovers kills the comfort of the ride and apparently when I take sharp corners, I will lean to the side like crazy, even worse than the stock springs. Thoughts anyone?
Thanks.
Old Feb 7, 2008
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: Tein Springs worth the worry in this case?
lol i would love to know where you get your information from. If you searched at all you should have found plenty of info on the subject here. The truth of the matter is no there wont be more lean in turns...quite the opposite actually. What I would say is a bad idea is springs on stock struts. Save up for springs+struts or full coilovers. springs+struts are about half the cost of tein ss coilovers (thats me overly rounding the prices) but you lose the adjustability. I ride on tokico HP blue struts and eibach prokits and the car handles much better than stock. You would probably want to get a upper front strut bar as well. I have a nuespeed bar and I love it.
Old Feb 7, 2008
robbclark1's Avatar
Retired suspension supermod.
finally, a good answer! good job nooblet!
I agree with this...do it right or don't do it at all. Slapping springs on your car will help lower the center of gravity an increase the spring rate, but eventually the stock shocks will get weak. Most people think springs are the most important component of handling when in reality, it is the tires, dampers, and sway bars.
Old Feb 7, 2008
ryox82's Avatar
lol thanks I think
Old Feb 7, 2008
Alright then. This clears it up for me, thanks. I guess I might as well wait for coilovers. Thanks a lot for the info.
Old Feb 7, 2008
ryox82's Avatar
No problem, thats what we are all here for. Good luck.
Old Feb 12, 2008
kcari's Avatar
trust me... i went cheap adn put S techs on Stock shocks and boy... did my car bottom out... i have tein basics now and i am riding low but no more bottoming out
Sep 26, 2023 06:44 PM
SidCivic
Sep 12, 2015 05:28 PM
Curtchuk
Aug 5, 2015 02:14 PM
knknif
Aug 4, 2015 06:11 PM
EM_WON
Jul 22, 2015 06:49 PM
