Alignment effect on steering responce
I recently got some new shocks for the back end and once I install them I'm gonna take the car in for an alignment. (Has never needed one since I got the car 4 years ago and 50000 miles
My question is how should I tell the shop to alter the alignment on the front end from stock specs to improve on center steering responsiveness and what other effects will this have on handling if any. And will there be a significant effect on tire wear?
I don't want nervous twitchy responce on/coming off center (If you have driven a honda fit you will understand)
I just want to tweek it a smidgen for a more wired, tight leather glove feel. As it is right now there is no dead zone, but directly on center while maintaining speed or coasting there is a sort of squooshy zone. If I am on the gas though it seems to feel tighter.
Feel free to point out my ignorance if I've made incorrect assumptions about anything
just enlighten me with the facts as well.
Thanks.
)My question is how should I tell the shop to alter the alignment on the front end from stock specs to improve on center steering responsiveness and what other effects will this have on handling if any. And will there be a significant effect on tire wear?
just enlighten me with the facts as well.Thanks.
Re: Alignment effect on steering responce
tell them to set ur toe to 0.
also tell them to giv you 1-3 degrees of camber...
believe it or not, a bit of camber will increase ur handling on turns.
"Increasing negative camber is one of the most effective and inexpensive ways to improve handling but is often overlooked on street cars. Negative camber in the 2 degree range will have little effect on tire wear but can have a dramatic affect on reducing understeer. Insufficient negative camber is the reason many driver school students destroy the outside edges of their front tires. For perspective, the front suspension of race cars are usually set up with 3 to 4 degrees (or more) of negative camber. However, this much negative camber would quickly wear out the tires of a street driven car that spends most of it's time going straight."
^^^ on a daily driven car, do not exceed 1.5 or even 1.25 degrees of negative camber. anymore is really oriented for track use and will significantly wear down your tires.
so do you actually give negative camber to the front only or all four corners. so if i'm reading it right. 0 toe, and negative 1 on camber. how will the tire tread be eaten up after maybe a year? drastically or minimal taking that your driving normally....and a little here and there turning fast onto onramp.
for better handling, you should give a little bit of negative camber on all four corners. its not necessary, however. with a -1 degree of camber, your tire wear will be normal.
if u r a daily street driver and not goin to the track or auto cross..i say the front should be 0 toe 0 camber. the rear should be 0 toe, -1 camber..this set up is in the civic manunal book.
high boost....our cars are fwd, so wouldnt -1 degree camber in the front also would help greatly on steering respone instead of just the back? plus da1lydr1ver said the tire wear isnt bad...once i get my rims, i think i'm going for the -1 degree all around since the tire wear will be normal....ty for the info....
u dont need to be an autoXer to have -1 camber....
its just better for corners...autox or not.
autox ppl ususally have lke 4+ degrees of camber.
again, anything below the 2 degree range(or 1, debatable) is OK...reserach it for urself if you dont believe da1lydr1ver or i
i was running -1.25 front and -.75 rear and i could tell the difference in handling. if its just a daily driver id say somewhere between (-.75 to -1.25) front and (-.5 to -1) rear with 0 toe. you can tell a difference with less understeer, which the stock specs help to ensure.
I STRONGLY disagree with this on a street driven car. I agree with what Da1lyDr1ver says. But only if your willing to sacrifice some tire wear should you ever deviate from factory specs
jdawgzcivic
17
Feb 1, 2020 04:16 PM
MamaBear2015
Sep 7, 2015 06:00 PM
